I have this Hydrogen Sulfide gas sensor and the datasheet says the supply voltage requires a regulated voltage with a min of 2.6v and max of 3.6v
I can’t find any datasheet for the nodemcu v3 (spent hours looking, but none mention anything relevant) that’s says whether or not the power output of the 3.3 pin is regulated (how can I tell?) but others have said an Arduino Uno’s 5v and 3.3v pins are regulated. Assuming it is regulated (I know what they say about assumptions), are there any reasons why I should be concerned about using the 3.3 pin?
What about using the aforementioned Arduino Uno, whose power pins are regulated?
This sensor is kinda pricey and I don’t want to burn it out due to stupidity.
The 3v3 rails of both NodeMCU and Arduino boards should indeed be regulated.
The more meaningful question is how much current they are able to safely provide to external devices. On Arduino boards where the MCU runs at 5v, the 3v3 rails are often produced by an on-chip regulator in the USB interface and don't have much current to spare.
In the NodeMCU case, the ESP8266 (or ESP32) is itself running off 3v3 so typically a SOT223 or SOT23-5 regulator is used. These generally have higher current capacity.
The data sheet for your device implies it draws 4 mA from the supply. Almost any discrete regulator would be chosen with enough margin to be able to supply that along with the on-board loads. It's fairly likely even the USB-chip's weak 3v3 supply as found in an Arduino could handle this, as long as you were not adding additional things as well.
It may be that using a separate regulator or various LC filtering approaches would yield a quieter sensor reading, but it would be worth seeing what you get in the easy case before worrying about that.
The Node MCU is supposed to have a regulated 3.3V supply (as with most, if not all micro breakout boards). The only snag is that different manufacturers/versions may use different regulators. You could lookup the datasheet for the regulator on your board to know for sure the current capability.
According this 1.0 schematic on github, an NCP1117ST33T3G is used:
Node MCU 1.0 schematic 3.3V regulator
However, as I mentioned, there are other variants:
Node MCU 3.3V regulator circled
(Image from ifuturetech.org)
You can see above that the board uses a 3.3V regulator labeled:
AMS1117
3.3 1552
The AMS1117 appears to be a cheap variant of the LM1117. I have found the AMS1117 on many cheap clones.
Here is one datasheet from Advanced Monolithic Systems, stating that the AMS1117 has a current limit of 1.1A "typical", and 1.5A max. Here is another datasheet that states 1.5A "typical", and shows no max. Fishy.
I would feel safer keeping it under 1A, or even 800mA.
As @ChrisStratton said, your sensor uses only 4mA. Thus it's probably safe to assume that your 3.3V regulator can afford the minute extra load.
