I want to learn how to size the series resistor for this optocoupler which has a high CTR.
I will use Arduino's 5V digital output pins for eight of this coupler so I really want to source necessary enough current from each pin.
What is the method to calculate the optimum like series resistor(R1 above) in this case?
  • \$\begingroup\$ Although I've no idea where those off-image wires go, it looks to me as though your 4N46 is struggling to be a high side switch with an NPN Darlington arrangement. Not so good. Take a look at the data sheet and find the test circuit examples there? Also, what is the highest frequency you hope to apply? \$\endgroup\$
    – jonk
    Commented Oct 26, 2018 at 3:04
  • \$\begingroup\$ @jonk What is not so good you meant? I think pin 6 should be not connected for this arrangement thats why there is green circle indicator. It is to turn on or off a device. Not repetitive use. So frequency is less than 1Hz in normal conditions. \$\endgroup\$
    – user1245
    Commented Oct 26, 2018 at 8:37
  • \$\begingroup\$ @atomant. That is not correct. The base pin is too set the gain of the transistor by connecting resistor from base to emitter. 100K will give you a gain of about 100. 470K will give you a gain close to 500. \$\endgroup\$
    – user105652
    Commented Oct 26, 2018 at 19:23
  • \$\begingroup\$ @Sparky256 see my other question electronics.stackexchange.com/q/402989/134429 they say pin 6 should be floating. What do you say??? \$\endgroup\$
    – user1245
    Commented Oct 26, 2018 at 20:06
  • \$\begingroup\$ Try reading the datasheet for a change. \$\endgroup\$
    – user105652
    Commented Oct 26, 2018 at 21:20
'IRLED' in this case means the infra-red LED inside the opto-coupler.
The IRLED drive current is Vin-1volt/R1. You subtract 1 volt from the source voltage to account for the IRLED Vdrop of 1.05 volts, then divide by R1.
In this case it should be 3.3V - 1 = 2.3V/1K = 2.4mA. That will drive most any opto-coupler.
There is no 'ideal' current except to try for minimum LED ON current x 2 or x 3. Whatever gives dependable results. That fact that it might have a maximum rating of 30mA is not what your looking for. Results for power conservation and heat control should be based on the IRLED minimum ON current that will saturate the output transistor fully ON-no more than that.
  • \$\begingroup\$ 3.3V will be 5V I will use 5V from Arduino pin out. So what is the goal to size the resisotr? To fit the current to 2.4mA? I dont understand.. \$\endgroup\$
    – user1245
  • \$\begingroup\$ I gave you the equation in my answer to solve R1 for any source voltage. It is very simple to use. \$\endgroup\$
    – user105652
    Commented Oct 26, 2018 at 11:20
  • \$\begingroup\$ Ok thanks so I can set the current to LED ON current X 2. Is the LED ON current written in the datasheet? \$\endgroup\$
    – user1245
    Commented Oct 26, 2018 at 11:30
  • \$\begingroup\$ Yes, the datasheet supplies all those details. \$\endgroup\$
    – user105652
    Commented Oct 26, 2018 at 19:17
