I have a scientific instrument that uses a DB9 cable to connect to the standard RS232 port on a computer for communication. I've deconstructed one of the cables as I needed to make another one but I am wondering if this wiring pattern is a standard wiring variation seen with DB9 cables or if it is completely proprietary. I don't want to have to make these cables if I don't have to.
\$\begingroup\$ Questions seeking recommendations for products get closed here. Can I suggest that you reword your question to ask for a solution to the problem rather than a recommendation for a product. \$\endgroup\$– RoyCOct 28, 2018 at 8:33
1\$\begingroup\$ It's more about identifying this particular pinout than about where to buy it. \$\endgroup\$– Dmitry GrigoryevOct 30, 2018 at 8:32
1 Answer
That is a standard null modem cable with handshake
also known as crossover
It is used to connect two DCE devices or two DTE devices together.
DCE (data circuit-terminating equipment) .... example: modem
DTE (data terminal equipment) .................... example: computer
TXD - transmit data
RXD - receive data
RTS - request to send
CTS - clear to send
DTR - data terminal ready
DSR - data set ready
1\$\begingroup\$ With both DTR/DSR and CTS/RTS handshake. There are cables without one or the other handshake in the wild. \$\endgroup\$– JankaOct 26, 2018 at 22:40
