When simulating I get a run time error, so I'm trying to run a RTL analysis in Vivado to see if the schematic of the component can be created at least. The code is the following
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
entity multiplicator_test is
generic(
WORD_SIZE: natural := 8;
EXP_SIZE: natural := 3
port(
input_1: in std_logic_vector(WORD_SIZE-1 downto 0);
input_2: in std_logic_vector(WORD_SIZE-1 downto 0);
result: out std_logic_vector(WORD_SIZE-1 downto 0)
end entity multiplicator_test;
architecture multiplicator_test_arch of multiplicator_test is
constant SIGNIFICAND_SIZE: natural := WORD_SIZE - EXP_SIZE - 1;
signal significand: std_logic_vector(SIGNIFICAND_SIZE-1 downto 0) := (others => '0');
signal exponent: std_logic_vector(EXP_SIZE-1 downto 0) := (others => '0');
signal sign: std_logic := '0';
signal aux: std_logic_vector((2*SIGNIFICAND_SIZE)-1 downto 0) := (others => '0');
begin
aux <= std_logic_vector(signed(input_1(SIGNIFICAND_SIZE-1 downto 0))*signed(input_2(SIGNIFICAND_SIZE - 1 downto 0)));
significand <= aux(SIGNIFICAND_SIZE - 1 downto 0);
exponent <= std_logic_vector(unsigned(input_1(WORD_SIZE-2 downto WORD_SIZE-EXP_SIZE-2))+unsigned(input_2(WORD_SIZE-2 downto WORD_SIZE-EXP_SIZE-2)));
sign <= input_1(WORD_SIZE-1) or input_2(WORD_SIZE-1);
result <= sign & exponent & significand;
end architecture multiplicator_test_arch;
When running the analysis, I get
ERROR: [Synth 8-690] width mismatch in assignment; target has 3 bits, source has 4 bits [(...)/multiplicador.vhd:27]
The line with the error is 27,
Apparently the target (aux) is 3 bits, but really it should be 8.
