I bought a arduino nano (ATmega328P Nano V3) and a led strip (sk6812 3535 4mm), to control the led strip with the arduino. Now i ran into problems with the power supply i guess.
The idea came from this video. First i soldered it like he showed at 4:03. But i messured the power at the VIN Pin and it was just ~4.2 V. Then i messured the 5V pin, which had like 4.8 V, so i resoldered the wires.
Right now it looks like this: I used the 5V charger from my mobile phone to power the Arduino. I cut down the 60 leds to 4, for testing
This is the current setup
So i guess i need to connect an external powersupply, like shown here, but to use 5V instead of 12:
I uploaded this code to the arduino:
#include <Adafruit_NeoPixel.h>
#define PIN 4
#define NUMPIXELS 4
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
void setup() {
  pixels.begin();
  pixels.setPixelColor(3, pixels.Color(0, 150, 0));
  pixels.show();
void loop() {
Now my questions:
1) Why does my current wireing not work with 4 Leds?
2) Do i need an additional power supply?
3) If i wire it like in the second picture, what can i use as power supply? Can i use any usb-cable, cut it and use it with a normal phone charger? Do i still need to power my arduino with usb b?
  • \$\begingroup\$ "V" is not the unit of power. \$\endgroup\$ – Long Pham Oct 28 '18 at 16:02
