I have a DC motor with an encoder attached. In the encoder's PCB there's a component I can't recognise labeled IR1. At first I thought it was an IR LED just by it's name and it being transparent. But why would I need an IR LED in an encoder? And, if it's not an LED, what is this component?
side view top view
  • \$\begingroup\$ please review this question and see if one of the answers satisfies it. \$\endgroup\$ Dec 29, 2018 at 16:55
IR LED for sure. Here is a similar part. TT Electronics OP140A. enter image description here
This does look like a IR led. I'm guessing the optical encoder is inside the black housing. Also this clearly has 2 pins meaning it can't be an encoder.
https://www.hamamatsu.com/jp/en/product/type/L6895-10/index.html
It looks like an optical encoder, in which case it needs a light source and at least two detectors. I suspect a pair of photodiodes or phototransistors inside the wheel, with the IR LED (which I'm almost certain it is) set up so that without interruption it shines on them evenly and equally.
IR because they tend to be cheaper and more efficient, if all you want to do is couple signal and neither visibility nor super-duper fine resolution is an issue.
    \$\begingroup\$ The "IR1" on the silkscreen might be a clue. :-) \$\endgroup\$
    – Oldfart
    Oct 28, 2018 at 16:16
