I need to use the medical ethernet magnetics by Pulse HXU6200NL (it is the only 2MOPP medical-certified PoE magnetics I can find). These are of the rather common transformer/choke coil topology. My confusion comes from the location of the common-mode choke coils.
As I understand common practice, and most magnetic data sheets I have seen (except by Pulse), you should place the common-mode chokes on the cable side of the magnetics. The intention being avoiding the injection of circuitry-generated EMI into an (unshielded) ethernet cable.
But Pulse places the chokes on what they denote as the PHY IC-side of the magnetics.
Which side is the correct one? Should I ignore Pulse's data sheet regarding this?
(There is a related, but unanswered, question regarding this)
My understanding of the common mode choke is that it works to prevent RF noise from entering from outside, as some Ethernet runs might be a hundred meters-by noisy power wires, and stops harmonics from the PHY drivers from getting outside and possibly violating FCC rules regarding EMI emissions.
The common mode chokes would serve no purpose on the PHY side, and I have seen no schematics with them on the PHY side. The PHY side actually must be as a clean as possible with just bias resistors at most. The PHY side drivers expect a very short connection directly to the magnetics. Designs vary so not all center taps are used.
Also I cannot say that nobody ever has or ever will use common mode chokes on the PHY side, with many designs being proprietary with no public release of certain details. As long as the PHY drivers can behave as they should I see no problem with that topology.
On the outside the center taps allow for PoE to be used without corrupting high speed data on the twisted pairs, as the supply current is common to both wires and at the magnetics it cancels out so no DC offset current is passed to the magnetics.
Usually twisted pair 'A' carries one side of the DC power and pair 'D' carries the other side. The 2 middle pairs are grounded unless the ports are rated for 1GB Ethernet.
  • \$\begingroup\$ On the receiver end of 100Base-TX, the common mode choke on the PHY side isn't uncommon. For 1000Base-T, it's not common, correct. \$\endgroup\$
    – Janka
    Oct 30, 2018 at 3:08
  • \$\begingroup\$ This answer is incorrect. PoE applications require the CM choke to be located in a place where it will not be saturated by the PoE current. \$\endgroup\$ Sep 15, 2023 at 22:04
In a PoE application, the positive DC power will be transmitted using any one or two pairs of the line. If common-mode choke is used on the cable side, it will try to reject this same voltage appearing on one of the pairs. So they have provided the CM chokes on the PHY side.
  • \$\begingroup\$ This is the correct answer. \$\endgroup\$ Sep 15, 2023 at 22:05
