I found an interesting interview question for FPGA engineer online - Implement a counter with Mux, so I decided to try to do that. I tried to keep it simple and so implement a counter with two bits, so it can count only to 3 and then reset.
I came to a conclusion I need 3 multiplexers, two for each bit, and the other one to serve as a frequency divider for the clock (I'm sure there are other ideas, would love to hear them as well). Note that I wanted this frequency divider to work at the falling edge of the clock.
Basically this is what I tried to do:
I used a clock of 1Hz just so it won't be too fast (though maybe it doesn't matter?), With mux1 being the frequency divider.
The idea here is that the counter is like this:
Q1 Q0
0 0
0 1
1 0
1 1
So, since Q0 changes with every clock edge, I connected the clock to mux3. Since Q1 toggles every two clocks, I tried to design a frequency divider which will make sure that Q1 will toggle every two clock (clk1) falling edges.
I thought it would work well, but in a simulation (used Multisim for that, because I don't know how to simulate it work circuitlab, would love if you could show me how I can do that), I got a very strange result - the simulation just stopped. Here is how it looked (the output of mux1):
When I zoomed in at the falling edge (at 500ms) it looked like this:
So my questions are:
- Why doesn't my frequency divider work?
- Is this implementation of a counter even good, if that frequency divider worked? Is this even possible?
