I am trying to do a program with my MSP430FR6989 from Texas Instruments. I send an Analogue signal to my ADC module in the uC, which converts it to a digital signal. If the value is greater than 0x800 (1.65 V), set a blue LED, else clear the blue LED
I am trying to do that with interrupts.
This is a snippet of my code
EDIT2 I added the whole code instead of the snippet
#include <msp430.h>
#define ENABLE_PINS 0xFFFE
void ADC_SETUP (void);
int main(void)
    WDTCTL = WDTPW | WDTHOLD;   // Stop watchdog timer
    PM5CTL0 = ENABLE_PINS;
    P4DIR = BIT3;
    ADC_SETUP ();
    ADC12IER0 = ADC12IE0;
    _BIS_SR(GIE);
    ADC12CTL0 = ADC12CTL0 | ADC12ENC;
    ADC12CTL0 = ADC12CTL0 | ADC12SC;
    while(1);
    return 0;
    #define ADC12_SHT_16      0x0200
    #define ADC12_ON          0x0010
    #define ADC12_SHT_SRC_SEL 0x0200
    #define ADC12_12BIT       0x0020
    #define ADC12_P92         0x000A
    ADC12CTL0 = ADC12_SHT_16 | ADC12_ON;
    ADC12CTL1 = ADC12_SHT_SRC_SEL;
    ADC12CTL2 = ADC12_12BIT;
    ADC12MCTL0 = ADC12_P92;
#pragma vector = ADC12_VECTOR//0xFFEA//ADC12_VECTOR
__interrupt void ADC12_ISR (void)
    if(ADC12MEM0 > 0x0800)
        P4OUT = BIT3;
    else
        P4OUT = 0x00;
when I build it, I get this warning.
#2580-D pragma vector = accepts numeric arguments or "unused_interrupt" but not ADC12_VECTOR
When I debug it, and my uC goes to Line A and the ADC12SC bit is set, it goes to isr_trap.asm, and my uC is stuck there
Kindly help me with this issue.
Start of EDIT_0
MSP430FR6989
Code Composer Studio 6.1.0
Compiler: TI v4.4.3
End of EDIT_0
Start of EDIT_1
I can't copy and paste the .map file here as it is too big, as I exceeded the character limit for this post.
Instead, I copied the file into a text file and sent it to this link.
https://we.tl/t-4aECqSr4yA
It is called ADC_ISR_UDEMY.map.txt
End of EDIT_1
Start of EDIT_3
Sorry for the late reply, I appreciate everyone's help in this thread.
I tried doing 3 projects, one with Timer A0 CCR0 ISR (ISR_TRAP_TIMER_TEST), one with ADC12_B ISR (ISR_TRAP_ADC_TEST), and one with ADC12_B isr with @GVelascoh Header (ISR_TRAP_ADC_HEADER_2).
ISR_TRAP_TIMER_TEST worked fine, the P1.0 LED was blinking
#include <msp430.h>
void init_Timer (void);
int main(void)
    P1DIR = BIT0;
    init_Timer ();
    _BIS_SR(GIE);
    while(1);
    return 0;
    TA0CTL = TASSEL__ACLK | MC__UP;
    TA0CCR0 = 3000;
    TA0CCTL0 = CCIE;
#pragma vector = TIMER0_A0_VECTOR //TA0 CCR0
__interrupt void Test_ISR (void)
    P1OUT = P1OUT ^ BIT0;
    //clear the flag
Build:
**** Build of configuration Debug for project ISR_TRAP_TIMER_TEST ****
"C:\\ti\\ccsv6\\utils\\bin\\gmake" -k all
'Building file: ../main.c'
'Invoking: MSP430 Compiler'
"C:/ti/ccsv6/tools/compiler/ti-cgt-msp430_4.4.3/bin/cl430" -vmspx --abi=eabi --data_model=restricted --use_hw_mpy=F5 --include_path="C:/ti/ccsv6/ccs_base/msp430/include" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-msp430_4.4.3/include" --advice:power=all --advice:hw_config=all -g --define=__MSP430FR6989__ --diag_warning=225 --display_error_number --diag_wrap=off --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU40 --printf_support=minimal --preproc_with_compile --preproc_dependency="main.pp"  "../main.c"
"../main.c", line 19: warning #112-D: statement is unreachable
"../main.c", line 17: remark #1527-D: (ULP 2.1) Detected SW delay loop using empty loop. Recommend using a timer module instead
'Finished building: ../main.c'
'Building target: ISR_TRAP_TIMER_TEST.out'
'Invoking: MSP430 Linker'
"C:/ti/ccsv6/tools/compiler/ti-cgt-msp430_4.4.3/bin/cl430" -vmspx --abi=eabi --data_model=restricted --use_hw_mpy=F5 --advice:power=all --advice:hw_config=all -g --define=__MSP430FR6989__ --diag_warning=225 --display_error_number --diag_wrap=off --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU40 --printf_support=minimal -z -m"ISR_TRAP_TIMER_TEST.map" --heap_size=160 --stack_size=160 --cinit_hold_wdt=on -i"C:/ti/ccsv6/ccs_base/msp430/include" -i"C:/ti/ccsv6/tools/compiler/ti-cgt-msp430_4.4.3/lib" -i"C:/ti/ccsv6/tools/compiler/ti-cgt-msp430_4.4.3/include" -i"C:/ti/ccsv6/ccs_base/msp430/lib/5xx_6xx_FRxx" -i"C:/ti/ccsv6/ccs_base/msp430/lib/FR59xx" --reread_libs --priority --warn_sections --display_error_number --diag_wrap=off --xml_link_info="ISR_TRAP_TIMER_TEST_linkInfo.xml" --use_hw_mpy=F5 --rom_model -o "ISR_TRAP_TIMER_TEST.out" "./main.obj" "../lnk_msp430fr6989.cmd"  -l"libmath.a" -l"libc.a"
<Linking>
remark #10372-D: (ULP 4.1) Detected uninitialized Port A in this project. Recommend initializing all unused ports to eliminate wasted current consumption on unused pins.
remark #10372-D: (ULP 4.1) Detected uninitialized Port B in this project. Recommend initializing all unused ports to eliminate wasted current consumption on unused pins.
remark #10372-D: (ULP 4.1) Detected uninitialized Port C in this project. Recommend initializing all unused ports to eliminate wasted current consumption on unused pins.
remark #10372-D: (ULP 4.1) Detected uninitialized Port D in this project. Recommend initializing all unused ports to eliminate wasted current consumption on unused pins.
remark #10372-D: (ULP 4.1) Detected uninitialized Port E in this project. Recommend initializing all unused ports to eliminate wasted current consumption on unused pins.
'Finished building target: ISR_TRAP_TIMER_TEST.out'
**** Build Finished ****
ISR_TRAP_ADC_TEST The uC still goes to the isr_trap.asm
#include <msp430.h>
void init_ADC (void);
int main(void)
    P1DIR = BIT0;
    init_ADC ();
    _BIS_SR(GIE);
    while(1);
    return 0;
    ADC12CTL0 = ADC12ON | ADC12SHT0_2;
    ADC12CTL1 = ADC12SHP;
    ADC12CTL2 = ADC12RES__12BIT;
    ADC12MCTL0 = ADC12INCH_10;
        P1OUT = BIT0;
    else
        P1OUT = 0x00;
Build:
**** Build of configuration Debug for project ISR_TRAP_ADC_TEST ****
"../main.c", line 22: warning #112-D: statement is unreachable
"../main.c", line 20: remark #1527-D: (ULP 2.1) Detected SW delay loop using empty loop. Recommend using a timer module instead
"../main.c", line 35: warning #2580-D: pragma vector= accepts numeric arguments or "unused_interrupts" but not ADC12_VECTOR
'Building target: ISR_TRAP_ADC_TEST.out'
"C:/ti/ccsv6/tools/compiler/ti-cgt-msp430_4.4.3/bin/cl430" -vmspx --abi=eabi --data_model=restricted --use_hw_mpy=F5 --advice:power=all --advice:hw_config=all -g --define=__MSP430FR6989__ --diag_warning=225 --display_error_number --diag_wrap=off --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU40 --printf_support=minimal -z -m"ISR_TRAP_ADC_TEST.map" --heap_size=160 --stack_size=160 --cinit_hold_wdt=on -i"C:/ti/ccsv6/ccs_base/msp430/include" -i"C:/ti/ccsv6/tools/compiler/ti-cgt-msp430_4.4.3/lib" -i"C:/ti/ccsv6/tools/compiler/ti-cgt-msp430_4.4.3/include" -i"C:/ti/ccsv6/ccs_base/msp430/lib/5xx_6xx_FRxx" -i"C:/ti/ccsv6/ccs_base/msp430/lib/FR59xx" --reread_libs --priority --warn_sections --display_error_number --diag_wrap=off --xml_link_info="ISR_TRAP_ADC_TEST_linkInfo.xml" --use_hw_mpy=F5 --rom_model -o "ISR_TRAP_ADC_TEST.out" "./main.obj" "../lnk_msp430fr6989.cmd"  -l"libmath.a" -l"libc.a"
<Linking>
'Finished building target: ISR_TRAP_ADC_TEST.out'
ISR_TRAP_ADC_HEADER_2 I still got the same issue, where the uC goes to isr_trap.asm (I hope I added your header right @GVelascoh)
#include <msp430.h>
int main(void)
    P1DIR = BIT0;
    init_ADC ();
    _BIS_SR(GIE);
    while(1);
    return 0;
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
__interrupt void ADC12_ISR(void)
        P1OUT = BIT0;
    else
        P1OUT = 0x00;
#elif defined(__GNUC__)
void __attribute__ ((interrupt(ADC12_VECTOR))) ADC12_ISR (void)
#else
#error Compiler not supported!
#endif
Build:
**** Build of configuration Debug for project ISR_TRAP_ADC_HEADER_2 ****
"../main.c", line 23: warning #112-D: statement is unreachable
"../main.c", line 21: remark #1527-D: (ULP 2.1) Detected SW delay loop using empty loop. Recommend using a timer module instead
"../main.c", line 37: warning #2580-D: pragma vector= accepts numeric arguments or "unused_interrupts" but not ADC12_VECTOR
'Building target: ISR_TRAP_ADC_HEADER_2.out'
"C:/ti/ccsv6/tools/compiler/ti-cgt-msp430_4.4.3/bin/cl430" -vmspx --abi=eabi --data_model=restricted --use_hw_mpy=F5 --advice:power=all --advice:hw_config=all -g --define=__MSP430FR6989__ --diag_warning=225 --display_error_number --diag_wrap=off --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU40 --printf_support=minimal -z -m"ISR_TRAP_ADC_HEADER_2.map" --heap_size=160 --stack_size=160 --cinit_hold_wdt=on -i"C:/ti/ccsv6/ccs_base/msp430/include" -i"C:/ti/ccsv6/tools/compiler/ti-cgt-msp430_4.4.3/lib" -i"C:/ti/ccsv6/tools/compiler/ti-cgt-msp430_4.4.3/include" -i"C:/ti/ccsv6/ccs_base/msp430/lib/5xx_6xx_FRxx" -i"C:/ti/ccsv6/ccs_base/msp430/lib/FR59xx" --reread_libs --priority --warn_sections --display_error_number --diag_wrap=off --xml_link_info="ISR_TRAP_ADC_HEADER_2_linkInfo.xml" --use_hw_mpy=F5 --rom_model -o "ISR_TRAP_ADC_HEADER_2.out" "./main.obj" "../lnk_msp430fr6989.cmd"  -l"libmath.a" -l"libc.a"
<Linking>
'Finished building target: ISR_TRAP_ADC_HEADER_2.out'
End of EDIT_3
Start of EDIT_4
Thank you for your help, I fixed my problem, I uninstalled CCS v6.1.0 and installed CCS 8.2.0, written the same program, and the problem is gone.
Thought I would share this, so I won't leave it hanging.
End of EDIT_4
  • \$\begingroup\$ Looks more like you uC doesn't know where to jump when ADC interrupt arrives, hence it panics. You have to tell your Interrupt controller to jump @ ADC12_Vector. Are you sure you are doing that? \$\endgroup\$
    – MaNyYaCk
    Oct 30, 2018 at 9:58
  • \$\begingroup\$ it only does that for ADC interrupt, not for the Timer0_A0 ISR for example. How do I fix it \$\endgroup\$ Oct 30, 2018 at 10:00
  • \$\begingroup\$ As far as I know, yes, I enabled ADC12 MEM0 interrupt, global interrupt, and when the value at ADC12MEM0 changes (conversion finished) it will jump to the ISR \$\endgroup\$ Oct 30, 2018 at 10:08
  • \$\begingroup\$ Well the warning seems to tell the story. ADC12_VECTOR seems to be unresolveable to a numeric value which the compiler expects. Are you sure you are using the correct symbol? \$\endgroup\$
    – Arsenal
    Oct 30, 2018 at 10:33
    \$\begingroup\$ What compiler are you using to compile that program? How is it configured? \$\endgroup\$
    – CL.
    Oct 30, 2018 at 11:56
From your map file, it seems like your ISR function is not compiled as there is no code associated with it. In the "section allocation map" you can find that there is no reference to the symbol ADC12_ISR
.text:_isr
*          0    00004400    00000020
                00004400    0000001a     rts430x_lc_rd_eabi.lib : boot_special.obj (.text:_isr:_c_int00_noargs_noexit)
                0000441a    00000006                            : isr_trap.obj (.text:_isr:__TI_ISR_TRAP)
This is a part of a map file for another project I have, see how ISR symbols are detailed in it:
.text      0    0000c600    00000d30
                0000c600    0000023c     main.obj (.text:main)
                0000cc62    0000007e     my-lib-Debug_2.lib : events.obj (.text:events_insert)
                0000cce0    0000007c                            : i2c_master.obj (.text:_isr:USCIB0_ISR)
                0000ce30    0000005e     port_interrupts.obj (.text:_isr:Port3_ISR)
Try cleaning your project and rebuild it again. Also, which files are you including, as the code you posted is not compilable as it is. Also, from the map file, I see you have another function, ADC_SETUP.
Edit: I just see that in your code you are not turning off the watchdog, which is enabled at start. Usually, this line is added at the beginning of the main function to do so: WDTCTL = WDTPW | WDTHOLD;
If your problem is due to compiler, this preprocessor conditionals will help you:
#else
#endif
  • \$\begingroup\$ Sorry for the confusion, when I posted I tried to just add a snippet of the code, not the whole real code, as I was trying to put relevant stuff of my code in this thread. ADC_SETUP is the same as init_ADC. I will change init_ADC to ADC_SETUP, and put the whole code (for reference).I did disable WDT, but I didn't think it was relevant to the post, so I didn't add it in my code, I just replaced it with //code \$\endgroup\$ Oct 30, 2018 at 16:12
  • \$\begingroup\$ I replaced the snippet of my code with the real code I am using \$\endgroup\$ Oct 30, 2018 at 16:19
  • \$\begingroup\$ I searched online for isr_trap.asm, and there are several links from TI forums that says that I isr_trap happens if I did not clear the interrupt flag, which I checked it was cleared, or enabled 2 Interrupts but there is only one ISR function, and the 2nd ISR is called the uC doesn't know wherer to go, which I also checked there is only one interrupt enabled (ADC12IE0) \$\endgroup\$ Oct 30, 2018 at 16:23
  • \$\begingroup\$ isr_trap.asm somehow a trap/breakpoint for my debugger if the uC felt there is something wrong with my interrupt, I will try again with 2 diff projects one for ADC ISR and the other of a Timer ISR and see how it goes \$\endgroup\$ Oct 30, 2018 at 16:32
    \$\begingroup\$ I uninstalled CCS 6.1.0 and installed CCS 8.2.0, and the problem was gone. Thank you for the help \$\endgroup\$ Nov 8, 2018 at 6:47
You must tell the compiler which microcontroller you are using. This is asked when creating a project, but can be changed later with Project → Properties → General → Device → Variant.
  • \$\begingroup\$ I did that, Variant: MSP430FRxxx \$\endgroup\$ Oct 30, 2018 at 15:29
