I am trying to compare watts exiting the battery vs watts being consumed by the bulb.
I have set up a test circuit shown below.
Test circuit
Should not A-B watts match C-D watts??
Sorry for such a basic question...I'm learning here...
  • 4
    \$\begingroup\$ If A-B watts did match C-D watts, then that would mean that \$R_1\$ was 0 Ω, or that the voltage across the resistor is 0 V and/or that the current through the resistor is 0 A. \$\endgroup\$ Oct 30, 2018 at 10:59
    \$\begingroup\$ And this is theoretical. In a real circuit, everything has resistance - even the wires. So there is power loss in every single piece. \$\endgroup\$
    – rdtsc
    Oct 30, 2018 at 12:12
You should also include the power dissipation from the resistor in there.
$$ P_{battery} = -(P_{resistor} + P_{lamp}) $$
What you are ignoring is the power consumed by \$R_1\$.
The product of AB (2.07W) is the total power supplied to the circuit, while the product of CD (0.48W) is the power consumed by the lamp.
$$P_{R_1} = (V_A - V_C)\ \times \ I = (6.15V - 1.434V) \times 0.335A = 1.58W$$
1.58W + 0.48W is 2.06W which is the power the battery is supplying to the circuit.
