I'm a newbie to STM32 coding and struggling with the following:
I used to code a little bit with STM32F103C8T6, using cubeMx and HAL libraries. I made a code using the following code to set the pin to High:
   GPIOB->BRR = STEP_Pin;
It worked like a charm.
I just try to move my project to an STM32F446RE Nucleo. I changed a few pieces of my code but I have a compiling error I can't get rid off.
../Src/main.c(175): error:  #136: struct "<unnamed>"  has no field "BRR"
I have this error for every single line using BRR. Do you know what I should change?
Config: CubeMx, Keil, HAL Lib, STM32F446RE
Thank you
    \$\begingroup\$ STM32F1 and STM32F4 GPIO are fairly different; you may have erroneous references/includes/code to the old target in your code \$\endgroup\$ – Chris Stratton Oct 30 '18 at 22:08
  • 4
    \$\begingroup\$ If I remember correctly the F4 doesn't come with a BRR definition. Instead you use the BSRR register and to reset a pin you have to shift it by 16. To set a pin you just use the pin directly. Make sure you are including the correct header and you are defining the right device as well. \$\endgroup\$ – Arsenal Oct 30 '18 at 22:10
BRR Register isn't defined for the GPIOs in the STM32F4 MCUs .You can use BSRR regster instead. for more information see the STM32F4-Reference manual page 286 and also STM32f4xx.h file for the registers have been defined for GPIOs.
  • \$\begingroup\$ I checked the RM but i'm not sure how to understand it. As example if i want to set PB5 named DIR; I will send GPIOB->BSRR = DIR_Pin; this is equivalent to: GPIOB->BSRR = 0x20; //(bit 5) When I went to reset, i will have to send: GPIOB->BSRR = 0x200000; // (bit 21) is it correct? \$\endgroup\$ – vib Oct 31 '18 at 10:22
  • \$\begingroup\$ yes, that's write. \$\endgroup\$ – Amin Oct 31 '18 at 11:54
By clicking "Post Your Answer", you agree to our terms of service, privacy policy and cookie policy
