On freshly installed LTspice on MacOS I have no libraries. In "Top directory is only /, but there is no way to edit this path, also in settings there is no tab described here:
How to change the top directory in LTspice?
Updated settings screens:
enter image description here enter image description here enter image description here enter image description here enter image description here enter image description here
maybe, there will be a way to edit configuration file manually, bu I don't know the key:
$ plutil -p Library/Preferences/LTC.LTspice.plist
  "AllowShortedCompPins" => 0
  "AutoDotRawDeletion" => 1
  "DampInductors" => 1
  "GridColor" => 9868950
  "InActiveAxisColor" => 9868950
  "NetlistEditorColor0" => 0
  "NetlistEditorColor1" => 32512
  "NetlistEditorColor2" => 16711680
  "NetlistEditorColor3" => 155
  "NetlistEditorColor4" => 16777215
  "NoJFETtempAdjIsr" => 0
  "NSNavLastRootDirectory" => "~/Documents"
  "NSNavPanelExpandedSizeForOpenMode" => "{712, 448}"
  "PlotLineThickness" => 1
  "PrintListing" => 0
  "RadianMeasure" => 0
  "RandomizeSeed" => 0
  "ReverseMouseWheelScroll" => 0
  "RoboMouse" => 1
  "SaveDeviceCurrents" => 1
  "SaveOneCurrentPerDevice" => 0
  "SaveSubcircuitDeviceCurrents" => 0
  "SaveSubcircuitNodeVoltages" => 0
  "SchematicColor0" => 16711680
  "SchematicColor1" => 16711680
  "SchematicColor2" => 16711680
  "SchematicColor3" => 16711680
  "SchematicColor4" => 12648447
  "SchematicColor5" => 0
  "SchematicColor6" => 0
  "SchematicColor7" => 0
  "SchematicColor8" => 13107200
  "SchematicColor9" => 16711680
  "SchematicColor10" => 65535
  "SchematicColor11" => 0
  "SchematicColor12" => 12632256
  "SchPenWidth" => 1
  "Solver" => 0
  "TSKtrtol" => 2
  "WaveColor0" => 0
  "WaveColor1" => 11513775
  "WaveColor2" => 65280
  "WaveColor3" => 16711680
  "WaveColor4" => 255
  "WaveColor5" => 11513600
  "WaveColor6" => 16711935
  "WaveColor7" => 8421504
  "WaveColor8" => 32768
  "WaveColor9" => 11468800
  "WaveColor10" => 32943
  "WaveColor11" => 8388736
  "WaveColor12" => 128
  "WaveColor13" => 44975
  • \$\begingroup\$ there is no tab described here .... why don't you post a picture of that also? \$\endgroup\$ – jsotola Oct 31 '18 at 17:59
  • \$\begingroup\$ I don't have the Mac version, but if there's no tab like the one in the linked answer, you can't edit them from the GUI. You could try to add SymbolSearchPath=/path/to/one;/path/to/two and LibrarySearchPath=/another/path;/yet/another/one and see if it works. If this one still doesn't, it most probably means you cannot do it in Mac. Is there anything about this in the Help? \$\endgroup\$ – a concerned citizen Oct 31 '18 at 19:55
  • \$\begingroup\$ The edit box Top directory is not editable. \$\endgroup\$ – vlk Oct 31 '18 at 19:59
    \$\begingroup\$ I suspect it is a bug and should be sent to the developers. I'm observing this behaviour under macOS Mojave, too. -- Christoph \$\endgroup\$ – Krischu Nov 19 '18 at 15:25
The Top directory has no effect. There are all the libraries, but are hidden, because the problem is in combination of dark theme in MacOS.
