I ordered a 110v soldering iron, but received one marked 220v 60w with a usa-compatible plug. If I plug into 110, will it still heat up?
closed as off-topic by Wesley Lee, Bimpelrekkie, DoxyLover, RoyC, pipe Nov 3 '18 at 11:53
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the use of electronic devices are off-topic as this site is intended specifically for questions on electronics design." – Wesley Lee, Bimpelrekkie, DoxyLover, RoyC, pipe
If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ Vote to close. That said, it will heat up since its basically a resistor. But less current than expected will flow and it won't heat up as much (by how much I dont know, since the heating element possibly doesnt have linear resistance wrt to voltage and temperature) \$\endgroup\$ – Wesley Lee Nov 1 '18 at 20:46
    \$\begingroup\$ Not for soldering... \$\endgroup\$ – Brian Drummond Nov 1 '18 at 20:49
  • \$\begingroup\$ your question makes absolutely no sense ..... you have the iron in your hand .... instead of plugging it in and observing the result, you ask this question ..... is there any information that you did not mention? \$\endgroup\$ – jsotola Nov 1 '18 at 21:14
Very likely yes, it will heat up. But it might not get hot enough to do any proper soldering. As the voltage is halved, so is the current. That means the power of 60 W will be divided by a factor of 4 so your 60 W iron will now only behave as a 15 W iron.
There are small soldering irons rated for 15 W so 15 W might be enough for some soldering jobs. It depends on how the iron is build, if it has a lot of metal it might take very long to heat up and/or radiate too much heat to become hot enough for soldering.
Anyway, you can safely try it out, as the mains voltage is lower than the iron's rated value it is safe to try.
  • \$\begingroup\$ Yes. I had a backup 60W 220V soldering iron that would heat up enough to solder on 110V. Not guaranteed to work on all models or ambient temps though. Also at 220V it would heat up too much for electronics work. \$\endgroup\$ – Wesley Lee Nov 1 '18 at 20:48
    \$\begingroup\$ That is my experience as well. Powerful irons get too hot. Low power ones take too long to heat up and aren't suitable for large connectors etc. For serious soldering a temperature controlled iron is a must. \$\endgroup\$ – Bimpelrekkie Nov 1 '18 at 20:50
