Here's the schematic:
I've tried to make this motor driver as tough as possible, but I'm still seeing occasional failures where the MOSFET and the diode D1 are both failed short.
Any ideas what could be causing this? Also is there anything I can do to make this driver even tougher?
Additional info: The motor is speed controlled by a microcontroller. The PWM duty cycle is capped around 60%. The motor can draw about 5A or more depending on the load, but this whole thing is powered by a switching power supply rated for 3.75A with a (fast) over-current shutoff, so that should limit the current in cases with excessive load. PWM frequency is approx 700hz.
I don't know what's burning out first, the mosfet or the diode. I tried replacing the diode (before I knew that the mosfet was also burned), and it burned out again after I toggled the interlock a few times.
