I tried to simulate the circuit given in your design note "https://www.analog.com/en/technical-articles/battery-protection-circuit.html"
According to the designer, the cut off voltage is 3V but the circuit is not going to cut off when the i/p is below 3V also.
Please see the attached simulation result. Could you please help me how to solve this issue?
simulation result
The problems with this simulations are:
  1. The circuit has no load. Use something reasonable, like 100 ohms.
  2. The PFET looks wrong, try something like FDS4465.
  3. Not sure what the V/V chart mean, I just applied a variable voltage V1.
  • \$\begingroup\$ Hi,it is working after connecting the load at the output.For determining the "lockout voltage" why they are not considering the VBAT. May I know why they are not writing KVL including VBAT \$\endgroup\$ – Hari Nov 3 '18 at 16:24
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
