I'm having some trouble with this ESP8266, to switch UP, DOWN, OFF dual relay, using Arduino code and a physical 3 states switch.
The code defines input GPIOs 12,14 as INPUT_PULLUP to avoid cases that from time to time ( say once a day ), I get a phenomena that is typically for not using a pull-up resistor.
What can cause such a thing? Can it be that GPIO12, GPIO14 does not HAVE a pull-up resistor on-board?
Relevant code (that defines inputs and outputs):
void setup() {
        Serial.begin(9600);
        pinMode(switchUpPin, INPUT_PULLUP);
        pinMode(switchDownPin, INPUT_PULLUP);
        pinMode(relayUpPin, OUTPUT);
        pinMode(relayDownPin, OUTPUT);
        digitalWrite(relayUpPin,HIGH);
        digitalWrite(relayDownPin,HIGH);
6
No, GPIO12 and GPIO14 have internal pull-up resistors (see table below). If they are properly setup in software I would suggest looking at the output (relay control circuit). Since you provided no information about the relay or how you control it I can't give a better answer.
ESP8266 pull-up table
Table from here
The NodeMcu has no pull-up on pins 12 and 14. The esp8266 has internal pull-up and you activate it with pin mode INPUT_PULLUP. Without activated internall pull-up, there is no pull-up for this pns.
  • \$\begingroup\$ As you can see in my code, it IS initiated with INPUT_PULLUP but the behaviour, scarcely, seems it does not have any. \$\endgroup\$
    – guyd
    Nov 3, 2018 at 18:07
  • \$\begingroup\$ you say that the internall pullup doesn't help? \$\endgroup\$
    – Juraj
    Nov 3, 2018 at 18:12
  • \$\begingroup\$ I say that, I had some occurrences that erratic triggering happened ... \$\endgroup\$
    – guyd
    Nov 3, 2018 at 18:14
  • \$\begingroup\$ ...while already using internal pull-up. I was not sure how to understand the question. So voltage drops while WiFi consumes too much power? \$\endgroup\$
    – Juraj
    Nov 3, 2018 at 18:17
  • \$\begingroup\$ you know I have my language limitations :) - Yes, it happened when PULLUP was already defined in code. I'm using a 2A DC adaptor, I doubt if the esp8266 consumes power in that scale. \$\endgroup\$
    – guyd
    Nov 3, 2018 at 18:41
