I need replacements for power supplies which output two voltages. For example, a Nintendo 64 needs 3.3V DC 2.7A and 12V DC 0.8A. There are readymade options but they seem to be of questionable quality. Can I combine two single output power supplies? Do I connect the output GNDs? What are the disadvantages to this approach; apart from maybe being overkill, cost- and space-inefficient? The advantage I see is that 100-240V AC to 3.3V, 5V, 12V, ... DC power supplies are readily available from reputable sources.
As an alternative, I could probably use an ATX power supply and just use some of the output voltages. Is that a better idea?
  • \$\begingroup\$ You list the N64 as an example; is this only an example, or are you actually looking to replace the power supply of an N64? \$\endgroup\$
    – Hearth
    Commented Nov 2, 2018 at 22:39
  • \$\begingroup\$ @Felthry I want to get a replacement for an N64 at some point, but others as well. I think a Neo Geo CD needs the rather uncommon combination of 5V and 10V. So I am not only asking for one application. :-) \$\endgroup\$
    – Higemaru
    Commented Nov 2, 2018 at 22:44
This is generally perfectly acceptable. The only major concern is that of power supply sequencing, meaning ensuring that the various power supplies:
  • start up in an acceptable order
  • reach their respective target voltages within an acceptable period of time
  • start up within a suitable window of time before or after each other.
This is important because an improper power sequence can cause disruptive or damaging currents to flow through the signal lines that connect components that are connected to different power supplies. Sequencing is more difficult to accomplish with two different power supplies versus one integrated system. You would have to carefully examine the requirements of the various loads to really determine if this is a problem.
As an aside, I'm not sure why an N64 would need 12V, unless it has a fan, which I don't recall.
Generally you would need to tie the negative outputs of the power supplies together if you need two positive voltages. It is also possible to use separate power supplies to produce positive and negative voltages by tying the positive output of one power supply to the negative output of the other, provided the negative power supply has no internal connection between its negative output and its chassis/equipment ground terminal.
A major advantage of combining power supplies in this way is that it's easy to create arbitrary sets of voltages and current capacities without incurring the substantial cost of designing and certifying a custom multi-output power supply. This makes it a very attractive solution for low volume products with high power requirements or requiring nonstandard voltages.
An ATX power supply could work, however given that you need less than 20W, even the smallest ATX supply is going to be tremendous overkill, and will not likely demonstrate good efficiency or regulation. Also, since most modern PCs derive most of their operating power from the 12V (via point-of-use step-down converters located near the CPU, GPU, and other low-voltage/high-current components), some power supplies sacrifice the efficiency and stability of the lower voltage rails to save cost while providing improved performance and efficiency on the 12V rail.
  • \$\begingroup\$ " since most modern PCs derive most of their operating power from the 12V" Is this true? So if I want to hack an ATX power supply to give me 12V I don't need the loading resistors on the +3.3V output anymore? \$\endgroup\$
    – TimWescott
    Commented Nov 2, 2018 at 22:31
  • \$\begingroup\$ @ajb Yes, there are no fans. It seems the video encoder gets 5V, stepped down from 12V. \$\endgroup\$
    – Higemaru
    Commented Nov 2, 2018 at 22:59
  • \$\begingroup\$ @ajb Thank you! I'm not sure I understand what power supply sequencing is; does it have to do with switching on power supplies in the correct sequence, i.e. adding a delay on one voltage line? (Is "power sequencing" the same thing?) (Sorry for the nickname confusion in my previous comment.) \$\endgroup\$
    – Higemaru
    Commented Nov 2, 2018 at 23:03
