I have a portable bearing heater which works with 3-phase 230 V power supply.
My power supply is 3-phase 380 V. Is there any way to convert the 3-phase 380 V to 3-phase 230 V? Please note that since the equipment is portable, it is important that the solution be portable too.
I added the picture of wiring diagram of the equipment. The manual indicates: The equipment is designed for 3 phase 230V power supply (Between each hot wire, 220 volts can be measured) when 2 phases are connected. it means 2 phases out of 3 phases are connected.
The supply power is 3-phase 380V,which means between each hot wire, 380 volts can be measured and between the neutral and any of hot wires, 220 volts can be measured
