So I'm really confused with mutual inductors and dot convention. If your answer is going to be a link to any website I can assure you I read them all and that only left me more confused. So here are my questions:
-> Should we write the absolute values of the mutual inductance? If so, why? Here is the example provided by my book:
They say that for the left side we have concordant coupling (mutual inductance positive) and therefore the series inductance is going to be:
$$L = L_{11} + L_{22} + 2 |L_M|$$
Why the use of the absolute value though? Isn't the coupling concordant and mutual inductance positive? What if it was negative, do you still have concordant coupling? I can see that if we apply the right-hand screw rule the fluxes have the same direction.
And for the right side discordant coupling (mutual inductance negative) and therefore the series inductance is going to be:
$$L = L_{11} + L_{22} - 2 |L_M|$$
Again: Why using the absolute value though? Isn't the coupling discordant (mutual inductance negative)? What if it was positive, do you still have discordant coupling? I can see that if we apply the right-hand screw rule the fluxes have opposite directions.
Next example my book provides is this one:
By applying the same thinking pattern of the previous one we have discordant coupling (mutual inductance negative) and therefore the series inductance is going to be:
HOWEVER, my book now provides this:
$$L = L_{11} + L_{22} + 2 L_M$$
I know that because \$L_M\$ is indeed negative this will lead us to the same result, however, why remove the absolute value now? Or are they assuming concordant coupling even though the mutual inductance is negative? Or is there a step I'm missing? This one didn't bother me so much because I ended up with the same answer.
However, the final case is where I drop the ball:
So here I had previously calculated the mutual inductance and found out it was indeed negative. The series connection also suggests to me that we have discordant coupling (by dot convention) and therefore the series inductance is going to be:
But now my book gives the answer:
$$L = L_{11} + L_{22} - 2 L_M$$
And since \$L_M\$ is negative this will originate different values.
I feel so confused right now, I have no idea how am I supposed to solve problems right this because I keep getting different answers. Can someone help me organize my line of thought. I think I understand concept of mutual inductance. What I don't understand is this thing with absolute values and series connection and I don't really know what to do.
  • \$\begingroup\$ It's probably just to emphasize the negative sign, I think. Otherwise you'd have the same equation twice which doesn't do too much to demonstrate that you have a reduced inductance. \$\endgroup\$ – Hearth Nov 3 '18 at 18:41
    \$\begingroup\$ "Next example my book provides is this one:" That is discordant coupling; the book must have been written by humans because they made an error (!). \$\endgroup\$ – TimWescott Nov 3 '18 at 19:14
  • \$\begingroup\$ that last one has a tangle of lines , but the coils look concordant to me, I flows into the page though the center hole for both windings. \$\endgroup\$ – Jasen Nov 3 '18 at 20:07
  • \$\begingroup\$ That tangle of lines is confusing, I can see it both ways. But if you just look at the direction of the magnetic flux those coils are concordant. \$\endgroup\$ – Edgar Brown Nov 3 '18 at 20:15
