I'm surprised when I'm working with Arduino Uno, by just sitting beside a portable radio, like when I was powered on both Arduino & Radio and when they are close to each other I got some noise issue in the audio of radio, later I tested with my mobile but didn't get that issue . I got to know later it's because of EM interference. Can anyone please share your views, why I got the issue with Arduino and why not with mobile?
\$\begingroup\$ The mobile is a complete system with built-in screening and interference mitigation. The Arduino is only a component - you supply the rest of the system yourself. Including that screening if the interference annoys you or stops other systems working. \$\endgroup\$– user_1818839Nov 5, 2018 at 8:19
\$\begingroup\$ @Brain drummond , what is the precautions that manufacturers taking while designing mobiles to mitigate interference issue (EMI) , Like What are the extra (specific) components that they are adding to the sysytem . \$\endgroup\$– sairamNov 5, 2018 at 9:22
\$\begingroup\$ What is the frequency of your "radio"? 100MHz, which is above the clock rate of Arduino. \$\endgroup\$– analogsystemsrfNov 5, 2018 at 11:27
\$\begingroup\$ A mobile phone doesn't have to add anything extra to avoid interference from your Arduino. The mobile phone signal is at a much higher frequency than the radio - at those frequencies, the interference from the Arduino will be far weaker. The other thing is that the mobile phone doesn't just directly convert the analog RF signal to an audio signal like your radio does. The voice on a mobile phone is transmitted in a very complex way. Anything that doesn't match its way of working won't be heard - the phone itself won't even "hear" it. \$\endgroup\$– JRENov 5, 2018 at 12:19
1\$\begingroup\$ Most radios are build using ancient designs from a time way before radio directives. They most often do not conform to ie the EU Radio Equipment Directive, and are therefore illegal but sold anyway. Whereas your mobile phone does conform to such directives and has been properly tested for immunity and emissions. The Ardunio is sold as a development board and thus except from all requirements, unless put inside a commercial product. \$\endgroup\$– LundinNov 7, 2018 at 11:51
