I am wondering how an Ethernet-to-CAN converter works. CAN is a multi-master broadcasting network where messages are associated with IDs. Each message type has a unique ID. Devices listen to all messages on the bus and decide whether an ID is of interest. Ethernet, however, uses point-2-point addressing, meaning that sender and receiver are specified. These information cannot be mapped on CAN, because there is not sender or receiver field.
Let's say, device A sends message m to device B. Device B is connected via CAN to the converter. Device A communicates over Ethernet.
  1. How does the CAN-to-Ethernet converter select the message ID when converting an Ethernet frame to a CAN fame? Are the same CAN IDs used for packets to the same recipient?
  2. How does the CAN-to-Ethernet convert a CAN message to an Ethernet frame? A CAN message has no recipient, but an Ethernet frame knows the recipient address. How does the mapping work?
    \$\begingroup\$ It doesn't convert them directly in the MAC layer, Most likely, it encapsulates the CAN packet inside a TCP packet and acts as a gateway. A link to a specific product would help. \$\endgroup\$
    – Lior Bilia
    Nov 5, 2018 at 15:16
  • \$\begingroup\$ This was a more general question without focusing on a specific product. \$\endgroup\$
    – null
    Nov 16, 2018 at 13:45
    \$\begingroup\$ That is the generic answer. The PHY and MAC layers are incompatible. Conversion has to be made on a higher layer. \$\endgroup\$
    – Lior Bilia
    Nov 16, 2018 at 16:19
It varies as per product manufacturer but generally speaking,
CAN-to-ETH converter reads all the messages from CAN Bus, packs every message as payload of ethernet datagram and sends it to computer. This payload contains CAN message ID, DLC and data.
On Computer, you can configure to filter out messages as per your requirements. Usually a DLL is provided and you can build your own application. Some even provide application where you can monitor the bus.
We use CAN-ETH converter from ProconX. Their user manual contains this simple diagram which will help you to understand: CAN-ETH Protocol description
Again, it depends on manufacturer and you can find details in the manual.
  • \$\begingroup\$ CAN-to-ETH: I am wondering what recipient is set in the Ethernet frame that contains s CAN message. CAN is a broadcast protocol, but Ethernet is point-to-point. Does this mean that such Ethernet frames are broadcasted as well? \$\endgroup\$
    – null
    Nov 16, 2018 at 13:54
  • \$\begingroup\$ What I use is UDP based which is a broadcast protocol. For TCP-IP, probably some configuration is required at start-up where a connection is established first and then communication over CAN is started. \$\endgroup\$
    – Swanand
    Nov 16, 2018 at 14:04
  • \$\begingroup\$ UDP is not a broadcast protocol (it can be used with any specific IP), but can also be used with broadcast or multicast IPs. The main difference with TCP is that UDP does not establish a connection and in consequence, it cannot ensure reception; this also make not possible broadcast over TCP. Also, UDP is part of TCP-IP (set of protocols ), while TCP is the alternative to UDP for the Transport layer of TCP-IP (difference between TCP and TCP-iP). \$\endgroup\$ Mar 25, 2020 at 12:11
  • \$\begingroup\$ @AdrianMaire Yes. That is correct. But UDP here is protocol of choice because it is connection-less AND supports broadcast - Similar to CAN. \$\endgroup\$
    – Swanand
    May 9, 2021 at 4:24
Software application programs that are setup to operate to CAN devices over an Ethernet connection will package the CAN protocol (including the IDs) into the data payload of the Ethernet connection. An intelligent processor in the Ethernet to CAN converter knows both CAN protocol and how unpack/pack that protocol into the Ethernet data payload. That device simply acts as a bridge between the Software application programs and the target CAN devices using the Ethernet as a convenient delivery service.
