I am having trouble with the 7107 IC. I have 5 of them on my PCB: 3 being used as current measurement and the other 2 are being used as a voltage measurement.
Only one of the 5 are displaying readings on the 7-segment display (may not be calibrated correctly but is showing something). The other 4 are the 7-segments are all blank. I have attached the circuit diagram below.
I have check the all 7-segments are working with the test feature on pin 37. The clock is oscillating at 40-43KHz (check with oscilloscope). The difference I am seeing with respects to the one working versus the others is that 100nF connected to cref+ and cref- on the working unit is pulsing about 1.3V, the others have no pulse or very low (mV) pulses.
I really starting to believe I have a bad batch of IC's. Please provide any tips or recommendations. Thanks in advance.
You are almost surely seeing the display 'blank' because you're ignoring the most significant digit (AB4 is open). The meters are in overrange (displaying + or - 1bbb where b is blank).
The 7107 works much better with a negative supply (+/-5V is ideal). If you want to use it with a single +5V supply you have to pay a lot of attention to the common mode range of the inputs, so it has to be more than 1V or something like that (read the datasheet) relative to analog COMMON.
    \$\begingroup\$ @JOHNDOE See the data sheet - it shows a charge-pump circuit using a CMOS inverter chip, a couple diodes, capacitors to generate a -ve voltage. \$\endgroup\$ – glen_geek Nov 5 '18 at 16:40
    \$\begingroup\$ As @glen_geek said. Or use a TPS60400DBVT, ICL7660 etc. charge pump to generate -5V regulated (my usual choice). \$\endgroup\$ – Spehro Pefhany Nov 5 '18 at 16:53
    \$\begingroup\$ So a negative 5 on pin 26 will make it work. Wish I knew this before I made the board. Hehehe guess I am always learning \$\endgroup\$ – JOHNDOE Nov 5 '18 at 17:10
    \$\begingroup\$ Some learning is more painful than others. And the painful varieties are often avoided if you read the entire data sheet. \$\endgroup\$ – WhatRoughBeast Nov 5 '18 at 18:46
    \$\begingroup\$ Note that you probably only need a single charge pump for the set of DVM chips if you use one like the 7660. The draw from the minus supply is only about 1mA each. \$\endgroup\$ – Spehro Pefhany Nov 5 '18 at 18:52
