Currently I have two microcontrollers connected to each other so that I have two serial ports. One to the PC and one to a wireless radio module.
Now I'm considering replacing one microcontroller with a hardware UART so that I can exchange parallel data to the PC. I'm avoiding parallel port because fewer PC's come with parallel ports.
I have a few questions:
Can I achieve 56kbps if I place this UART in synchronous mode?
Can I send a byte of data to the uart by applying data to the P1 line and pulsing WR low when a signal on the UART is in a ready state?
Can I receive a byte in a similar way (where I pulse RD low instead and receive contents on P1)?
Will I always need to receive and process data within a certain time limit especially if the PC decides to ignore any flow control in use by the UART?
circuit
  • \$\begingroup\$ what is P1 line? ..... have you referred to the hardware UART datasheet for the answers? \$\endgroup\$ – jsotola Nov 5 '18 at 23:37
  • \$\begingroup\$ Why the 8052? Is this a school assignment? \$\endgroup\$ – Reinderien Nov 6 '18 at 0:13
  • \$\begingroup\$ It is what I have and for its price point, its much cheaper plus I even can program it easier than other chips. \$\endgroup\$ – Mike Nov 6 '18 at 23:08
