I cannot find any information about a practical problem I encounter.
If we don't have crimping tools, when soldering wires to tab terminals with holes as below:
Do we need to pass the wire through the hole before soldering? But sometimes the wire is much thicker than the hole, in that case is it fine to solder the wire tip on the tab terminal's surface?
I couldn't find any examples about this.
