7
Do you know this connector? I tried in vain for hours using a variety of search terms.
Pitch is 2.54 mm and width of arc-bent contact is 1.4 mm. I just wish to find a part number, manufacturer and/or a different connector that is very similar to this.
2.54mm pitch connector
EDIT 1
  • \$\begingroup\$ SMD of the same connector above would suffice, too. The arc-bent part on top is what I need. \$\endgroup\$
    – mlomailom
    Commented Nov 6, 2018 at 14:04
  • \$\begingroup\$ Oh! I didn't understand, I thought the bent part was the leads you'd solder.to a board; my suggestion wouldn't work. \$\endgroup\$
    – Hearth
    Commented Nov 6, 2018 at 14:05
  • \$\begingroup\$ It would be helpful if you would state how it is used. What connects to the bent parts? To their lower or upper surface? Are you trying to repair something such that alternatives might work, or are you trying to source this for new production? \$\endgroup\$ Commented Nov 6, 2018 at 14:26
  • \$\begingroup\$ @ChrisStratton Added. Dimensions aren't that important as I'm looking for something similar. It's for a prototype initially. Mass production is too far off to prepare for it right now. \$\endgroup\$
    – mlomailom
    Commented Nov 7, 2018 at 8:57
  • \$\begingroup\$ When you say "card", is that a PCB with a hole on its side or like stacked PCBs? \$\endgroup\$ Commented Nov 7, 2018 at 12:00
That looks to me like one of these oldschool LCD panel connectors. One would use two and slot the LCD glass inbetween:
The connectors:
connectors
Type of LCDs used with those:
an LCD used with said connectors
I haven't looked anywhere as to where can one source them for any serious production runs; but I hope this might point you in the right direction.
Source:
I am in no way affiliated with said shop; I just once found those on there.
  • \$\begingroup\$ Perfect! Exactly what I was looking for. Thanks for your research. \$\endgroup\$
    – mlomailom
    Commented Nov 12, 2018 at 9:04
  • \$\begingroup\$ Nice one! I read almost the whole catalogue from Molex, Amphenol and Hirose and did not find any similar connector. \$\endgroup\$ Commented Nov 12, 2018 at 14:16
Similar, but different. Surface mount compression contacts. https://www.digikey.com/short/j02v3j enter image description here
  • \$\begingroup\$ Thanks. It helps, but it isn't a solution for me right now. I'll keep looking for the origin of the original part I'm looking for, though. \$\endgroup\$
    – mlomailom
    Commented Nov 7, 2018 at 8:59
