I will like to use AS7 IDE to program the Arduino board, for start Im using Arduino UNO with ATMEGA328P-PU chip. Im using Windows 10 professional
First I used the Arduino IDE in order to run/confirm this simple program that blinks the orange LED (pin 13) in a Fibonacci pattern up to Fib 100. The program uploads & works fine using Arduino IDE.
Arduino code:
void setup() {
// put your setup code here, to run once:
pinMode(13,OUTPUT);
void loop() {
// put your main code here, to run repeatedly:
int i = 0;
int n =100;
int t1 = 0;
int t2 = 1;
int numberOnOff;
for ( i = 1; i<=n; i++)
numberOnOff = t1 + t2;
t1 = t2;
t2 = numberOnOff;
delay(3000);
int counter = 0;
while (counter < numberOnOff)
onOff();
counter++;
void onOff()
digitalWrite(13,HIGH);
delay(1000);
digitalWrite(13,LOW);
delay(1000);
Then I migrated to AS7 IDE & used this video tutorial : https://www.youtube.com/watch?v=zEbSQaQJvHI
step 1) I copied the Arduino upload command & formatted it:
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr\bin\avrdude.exe
-C"C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr\etc\avrdude.conf" -v -patmega328p -carduino -PCOM6 -b115200 -D -Uflash:w:"$(ProjectDir)Debug\$(TargetName).hex":i
step 2) I navigated to AS7 "Tools" menu, then "External Tools", then created a build tool titled using copied paths from step 1 "Arduino_via_bootloader":
I set the value of Command =
And the value of Arguments =
Clicked OK & apply.
step 3) Then I modified my C code (main.c) :
* Arduino2.c
* Created: 11/6/2018 5:48:19 PM
* Author : cyber101
#define F_CPU 16000000
#include <avr/io.h>
#include <util/delay.h>
void loop();
void onOff();
int main(void)
/* Replace with your application code */
while (1)
loop();
void loop() {
int i = 0;
int n =100;
int t1 = 0;
int t2 = 1;
int numberOnOff;
t1 = t2;
t2 = numberOnOff*3;
_delay_ms(3000);
int counter = 0;
onOff();
counter++;
void onOff()
/* Insert application code here, after the board has been initialized. */
PORTB |= 0B00100000;
_delay_ms(1000);
PORTB &= 0B11011111;
_delay_ms(1000);
step 4) I Build the project & got success:
Done executing task "RunCompilerTask".
Using "RunOutputFileVerifyTask" task from assembly "C:\Program Files (x86)\Atmel\Studio\7.0\Extensions\Application\AvrGCC.dll".
Task "RunOutputFileVerifyTask"
Program Memory Usage : 308 bytes 0.9 % Full
Data Memory Usage : 0 bytes 0.0 % Full
Done executing task "RunOutputFileVerifyTask".
Done building target "CoreBuild" in project "Arduino2.cproj".
Target "PostBuildEvent" skipped, due to false condition; ('$(PostBuildEvent)' != '') was evaluated as ('' != '').
Target "Build" in file "C:\Program Files (x86)\Atmel\Studio\7.0\Vs\Avr.common.targets" from project "c:\users\anaim\Documents\Atmel Studio\7.0\Arduino2\Arduino2\Arduino2.cproj" (entry point):
Done building target "Build" in project "Arduino2.cproj".
Done building project "Arduino2.cproj".
Build succeeded.
========== Build: 1 succeeded or up-to-date, 0 failed, 0 skipped ==========
step 5) Finally, I navigated to the "Tools" menu & selected my custom build "Arduino_via_bootloader". However nothing happens, AS7 Output console is empty to messages, no errors, no feedback? And the board is not blinking. How can fix this build process???
Thanks a million.
