So I'm planning to make a charger that can charge multiple lithium batteries in parallel with hope to use recycled one. I fully understand that they are dangerous when you do it incorrectly, so I just want to make sure first.
My design involves the batteries have common ground and each of the positive has a MOSFET, each of which is controlled by an Arduino
I can individually address the batteries by opening and closing the MOSFETs. My question is how can I charge the batteries as quickly as possible. I can just charge one at a time and discharge 1 at a time, but that seems inefficient.
My plan is to charge all the battery individually until the voltage meter reach 4.2V (The battery voltage can be like 3.9 or 4.1, but the charger keeps it at 4.2). Once all of them allow the charger to stay at 4.2V, open up all of the gates and charge all the battery in parallel. This is the part that I'm unsure. Since the voltage of the charger will remain at 4.2V, this shouldn't be a problem right?
In case the charger got disconnect, all of the gates will close to isolate the battery. The Arduino will then read each of the voltage of the batteries by open the corresponding gates, finding batteries that are at 4.2V and open those gate to discharge. This would also won't cause a problem right?
Edit: I'm actually gonna use a shift register powered at the right voltage to control the MOSFET, I just simplified it with the Arduino
    \$\begingroup\$ Just a note, the way you have the IRF530 connected, it will not turn on (it's an N-channel FET), review the datasheet note Vgs threshold voltage, etc. You don't give a charge rate for your batteries, but this FET is not really designed to be driven by a 4V gate voltage. There is also the matter of the body diode on the FET, which will backfeed current if the charging voltage is lower than the battery voltage. There's no info on the battery charger detailing how it would respond to the transient(s) when you switch in the batteries. \$\endgroup\$ – isdi Nov 8 '18 at 13:24
  • \$\begingroup\$ FYI - Charge time is largely dependent on the current limit during the constant-current phase of the charge. \$\endgroup\$ – ddurgin Nov 8 '18 at 16:14
The Voltage you want to measure is the open circuit voltage (OCV), which is the voltage of the battery, when no current is flowing trough it. So you would need to disconnect the charger to measure the exact OCV.
The OCV is then related to the state of charge (SOC) according to the graph in the datasheet.
Charging the cells in parallel is an easy method to balance the cells, but as ddurgin said, your current limit influences the charge time. If your charger is set to charge at 1A and you charge 4 cells in parallel, this will result in .25A per cell (on average), so it would take four times as long.
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
