I was wondering if it was possible to model and simulate my WPT system in MATLAB to determine if my analytical calculations are correct. I want to model my system in MATLAB as I have seen on MathWorks you can do this for a circular spiral coil. Any help will be greatly appreciated thanks.
wireless power and Modeling Resonant Coupled was added to Matlab2017. I used it for wireless power transfer model, but you can change the geometry and model, frequency of simulation.
You can change this model:
https://www.mathworks.com/help/antenna/examples/modeling-resonant-coupled-wireless-power-transfer-system.html
Edit: In function "createSpiral.m" change delta_phi "delta_phi=pi/2;" The output like this: enter image description here
For simulation, you should change createFeed(spiralobj,...,...); point base on new feeder configuration
  • \$\begingroup\$ Hi, Thank you for your reply. I have given that a read and my problem is in changing the geometry to simulate a square spiral. I don't know how and any help will be greatly appreciated. \$\endgroup\$ – william fashanu Nov 15 '18 at 0:49
  • \$\begingroup\$ @williamfashanu, I updated the post for square spiral. \$\endgroup\$ – M KS Nov 15 '18 at 17:52
