I've done most of the legwork. I've got this design working using 2 set reset(SR) flip flops, but I need to make it using 2 data flips, a.k.a D flip flops.
What I did:
Note the numbers not in brackets are in base 10, the numbers in brackets are in base 2.
State Diagram
Note the truth table for a set(S) reset(R) flip flop.
S R | Q(output) | !Q
0 0 | no change | no change
0 1 | 0 | 1
1 0 | 1 | 0
1 1 | indeterminate | indeterminate
| (sometimes 0, | (sometimes 0,
| sometimes 1) | sometimes 1)
- Present State is represented by P.S,
- Next State is represented by N.S,
- A is my most significant bit of input
- B is my least significant bit of input,
- x represnts don't care,
- ! represent not
P. S | N. S | A | A | B | B
A B | A B | Set | Reset | Set | Reset
0 0 | 0 1 | 0 | x | 1 | 0
0 1 | 1 0 | 1 | 0 | 0 | 1
1 0 | 1 1 | x | 0 | 1 | 0
1 1 | 0 0 | 0 | 1 | 0 | 1
Through K-Map I got:
- Set of A = !A and B,
- Reset of A = A and B,
- Set of B = !B,
- Reset of B = B
This is my design using 2 SR flip flops:
If someone could help me create a circuit with the same functionality except using 2 D flip flops, that would be greatly appreciated.
dot
command:digraph{rankdir=LR;"0(00)"->"1(01)"->"2(10)"->"3(11)"->"0(00)";}
I'm really starting to wish that this was built right into the website.) \$\endgroup\$
