I've been working on making a tube based headphone amplifier as a fun personal project. The amplifier is based around this 12AU7 vacuum tube. The project for the most part is following this existing design. It's currently being powered by a 12V lead acid battery. Here's the circuit diagram:
ckt diagram
After assembling everything on a piece of perfboard and testing, it sounds great! However, there seems to be an intermittent noise that I can't seem to identify. This noise is not always present; sometimes the amp will run fine for several minutes without problem, other times the noise will start and last only a few seconds, but sometimes it lasts for minutes at a time. It appears independent of input. I have heard it while listening to music as well as when no input is connected. Here's what it looks like. This was created by recording the output of the amplifier using the line-in of my pc and analyzing the data in Matlab.
noise
There are strong peaks at 60Hz (I'm in the US) in both channels which makes sense as the input comes from a 1m cable running across my desk. What I don't understand is the popping. It also appears to be worse in the left channel despite the two paths being identical. This is only one sample, but the popping seems to be consistent across occurrences based on what I've heard and other samples I've recorded.
Here's what I've tried so far:
  1. Removing the input. Even with no input cable connected to the amplifier, this popping is still present. This also means the noise is independent of the volume set by P1A.
  2. Changing the tube. The noise is present with the extra 12AU7 tube I have and even with no tube.
  3. Using different headphones. I typically use this amp with my Audiotechnica ATH-M40X with a 35 Ohm impedance but the noise exists with my cheap ear buds as well (8 Ohm I think).
This leads me to think that it likely has something to do with either the IRF510 MOSFET or LM317 linear regulator (which is acting as a current source). I don't know enough about the noise performance of these components to conclusively put the blame on either of them. If it matters, they both run very hot. I can record some exact temps later if necessary. I can't rule out the power source or passives as potential culprits, but again, this is beyond my knowledge.
Any suggestions? What is the likely cause of this noise? Are there things I can do to learn more about the noise and narrow down possibilities? How can I get rid of it?
  • \$\begingroup\$ I'm wondering if there's a bad connection somewhere. That can cause plenty of popping. Double check your solder joints? \$\endgroup\$
    – Hearth
    Nov 9, 2018 at 22:07
  • \$\begingroup\$ Welcome to EE.SE. Are you running the tube filaments on AC or DC current? Also R1 and R2 could easily be 1M resistors. It this in a metal enclosure? \$\endgroup\$
    – user105652
  • \$\begingroup\$ Having MOSFET's and LM317's running hot is NOT good at all. Popping noise can be a sign of a bad semiconductor. The popping will get worse with time. What voltage is Vcc and is it the same for the tube anodes? \$\endgroup\$
    – user105652
    Nov 9, 2018 at 22:10
  • \$\begingroup\$ @Sparky256 Running off of DC current from a lead-acid battery currently. It is not in a metal enclosure, right now it's not in any closure at all. Vcc is nominally 12V and is the only positive voltage rail in the system. \$\endgroup\$
    – Nick J
    Nov 9, 2018 at 22:12
    \$\begingroup\$ You are running filaments very hot - tube life will be shortened considerably. \$\endgroup\$
    – glen_geek
    Nov 9, 2018 at 22:44
After looking at several different forms of transistor and general circuit noise, I accidentally discovered the answer was RF interference from my cell phone. I'm not sure which specific part signal it is, but I notice it more when my phone is sending and receiving text messages. My carrier is Verizon and phone Samsung, I don't have access to any others to determine if it is specific to this or a problem in general.
This noise is not unique to my amp. I've since heard the noise in several solid-state amplifiers including a turntable with built-in equalizer amp and a digital piano with built-in speakers. I'm assuming the RF interference could be mitigated with some better design, but that will have to wait for another day.
