A) Derive the expression for \$ \mathcal{H}(s)\$ where \$\mathcal{H}(s) = \frac{V_o}{V_i}\$
I started by using the voltage divider at the \$V_{out}\$ node.
\$V_o = \frac{R}{R_c+\frac{1}{sc}+R}\ \cdot V_i\tag1\$
B) At what frequency will the magnitude of \$H(j\omega)\$ be maximum?
The frequency response of the system is as follows
\$ \mathcal{H}(s) = \frac{CRS}{CRS+CR_CS+1} = \frac{RCS}{(R+R_C)CS+1} = \frac{\frac{R}{R+R_C}S}{S+\frac{1}{(R+R_C)C}} \tag2\$
\$ \mathcal{H}(j\omega) = \frac{\frac{R}{R+R_C} j\omega}{j\omega+\frac{1}{(R+R_C)C}}\tag3\$
The magnitude will be maximum when the frequency is infinity. This is because when the frequency of the voltage source is infinite (\$\omega = \infty \$), the capacitor behaves as a short circuit, and thus there is no voltage across the capacitor.
\$ \mathcal{H}(j\omega) = \frac{\frac{R}{R+R_C} \infty}{\infty+\frac{1}{(R+R_C)C}} \tag3\$
However, why wouldn't \$ \omega = 0\$ work? Because the capacitor will act as an open circuit when the frequency is zero thus \$V_{out}\$ will receive no voltage. Therefore, \$ \omega = 0\$ is minimum.
C) What is the maximum value of the magnitude of \$ \mathcal{H}(j \omega)\$?
\$ |\mathcal{H}(j\omega)|_{max}=\frac{R}{R+R_C}\tag4\$
D) At what frequency will the magnitude of \$\mathcal{H}(j\omega) \$ equal its maximum value divided by \$ \sqrt{2}\$
We start off finding the magnitude of the transfer function
\$ | \mathcal{H}(j \omega)| = \frac{\frac{R\omega}{R+R_C}}{\sqrt{\omega^2+(\frac{1}{(R+R_C) \cdot C}})^2} \tag5\$
Now we can use the equation \$ | \mathcal{H}(j \omega_c)| = \frac{ | \mathcal{H}(\omega)|_{max}}{\sqrt{2}} \$ to solve for the cutoff frequencies
\$ \frac{\frac{R\omega}{R+R_C}}{\sqrt{\omega^2+(\frac{1}{(R+R_C) \cdot C}})^2} = \frac{\frac{R}{R+R_C}}{\sqrt{2}} \tag6\$
Solving for \$ \omega \$ in this equation I get
\$ \omega^2 = \frac{1}{C^2(R+R_C)^2} \rightarrow \omega = \frac{1}{C(R+R_C)} \tag7\$
E) Assume a resistance of 5 ohms is connected in series with the 80 \$\mu F\$ capacitor in the circuit. \$R_C\$ is 20 ohms. Calculate \$\omega_c\$
\$ \omega_C = \frac{1}{C(R_C+R)} = \frac{1}{(80 \times 10^{-6})(5+20)} = 500 rad/sec\$
Plugging this back into the transfer function:
\$\frac{\frac{20}{20+5}j\times 500}{j \times 500+\frac{1}{(20+5)\cdot (80 \times 10^{-6})}} = 0.5656 \angle 45\tag8\$
  • \$\begingroup\$ For B: When you "simplified" the equation your frequency ended up in many terms. It is easier to work with the not simplified expression. There only 1/jwC depends on the freq. It goes to zero for max freq which gives the max output voltage. \$\endgroup\$
    – Oldfart
    Nov 11, 2018 at 1:00
  • \$\begingroup\$ @Oldfart Why does removing the frequency (letting it go to zero) give the max output voltage? Is it because the capacitor behaves like an open circuit when its frequency is = 0? Because of this all the voltage will be across the open and \$V_{out} = V_{in}\$? \$\endgroup\$ Nov 11, 2018 at 1:10
  • \$\begingroup\$ I apologize I can't edit my previous comment. It should be because when the frequency of the source is infinity then the capacitor will act as a short circuit. This means that \$V_{out} = V_{in}\$ \$\endgroup\$ Nov 11, 2018 at 1:26
In the limit, as the frequency approaches infinity the term involving C tends to zero. This makes calculating the magnitude easy, since the imaginary part vanishes. Mathematically, the magnitude of the transfer function is the magnitude of the top divided by the magnitude of the bottom. The top part is trivial. The bottom part is the square root of the sum of the imaginary part squared and the real part squared. Only the bottom varies with frequency. To maximise the magnitude, minimise the bottom part.
