Let's say that there is a simple circuit with the following components (ignore values):
  • LEFT: a simple power supply (assume DC)
  • TOP: load (resistor) and inductor
  • RIGHT: switch
  • BOTTOM: load (resistor)
I have come across numerous sources that indicate that if the SWITCH suddenly moves from a CLOSED position to an OPEN position, the circuit and its components can potentially be compromised if unprotected:
  • When the switch opens, the current across the entire circuit will drop to zero really quickly (assume instantaneously), resulting in a back EMF
  • The resulting back EMF voltage according to the inductance formula will be very high as the change in time will be very small
  • The high voltage produced by this back EMF has the potential to damage the circuit and its components
Below are some assumptions that I hold, please advise if any of them are incorrect or incomplete:
  1. When the switch is closed and has reached steady state, a current will be passing through the circuit in accordance with Ohm's law (V = IR) or somewhere near there.
  2. When the switch is closed and has reached steady state, the current passing through every wire on the main circuit is uniform (i.e. the wire before and after the power supply has the same current passing through it).
  3. Current is the main factor that controls whether the wire in the circuit is damaged or not.
  4. When the switch is opened, the resistance across the open circuit remains the same as it was when the switch was closed, therefore the current generated by the back EMF through the circuit inversely proportional to the voltage generated by the back EMF (Ohm's Law).
  5. Since the current passing through the open circuit is equal to or lower than the current passing through the closed circuit (inductance over short period of time), the wires and its components should be able to withstand the back EMF without any damage (exception are voltage sensitive components such as transistors, diodes, etc).
What scenarios would result in the back EMF potentially damaging the circuit and/or its components and what solutions could be taken to mitigate the problem?
  • \$\begingroup\$ With this low voltage and current, probably not much. In steady-state, your inductor will have 0.5*1μH*(5mA)² = 12.5 pJ stored in it. I doubt a dozen picojoules is enough energy to damage anything. At least nothing that isn't nanoscale. \$\endgroup\$
    – Hearth
    Nov 11 '18 at 13:02
  • \$\begingroup\$ @Felthry Yeah, the diagram was meant to be value-less, unfortunately I was not sure how to do that. But assume that the circuit values were more reasonable, where the voltage is much higher and the resistors are much lower. I am more interested in getting the concept behind it rather than a specific analysis to this example. \$\endgroup\$ Nov 11 '18 at 13:12
    \$\begingroup\$ I'm a bit unsure whether this is news to you, but: google "flyback diodes" and why they're used with transistors switching inductive loads, e.g. motors. \$\endgroup\$ Nov 11 '18 at 13:37
  • \$\begingroup\$ Thanks, relatively new to the entire thing and it seems the explanation of why flyback diodes seems to answer this question. I would upvote your comment but it seems that I am too new to do that. \$\endgroup\$ Nov 11 '18 at 20:22
As far as your many questions,
#1&2 are correct.
#3 may or may not be true.
#4 I'm not sure what you are trying to say, but the current after the switch opens will ideally be the same as before it was opened. That's a paradox with an ideal switch and an ideal L-R circuit (voltage would have go to infinity to maintain the current through an open switch), but real circuits are not ideal.
It may help if you visualize a high value resistor, a capacitor or a spark gap across the switch. In a real situation something will limit the voltage, either the switch or wiring will break down, there will be some resistance or capacitance that will limit the voltage. In the case of capacitance it will cause ringing.
#5 This is not necessarily true. The energy (previously stored in the inductance) can cause damage even if the current would not be an issue. For example when a mechanical switch opens, the resulting high voltage at near the previous current causes arcing and erodes the contacts. Of course the energy is \$L\cdot I_0^2/2\$ where \$I_0\$ is the current flowing just prior to the switch being opened.
Since usually the switch is a semiconductor in modern circuits, much of the energy will be absorbed by the semiconductor. Some may be absorbed by external resistances (for example, a relay coil with a flyback diode across it depends mostly on the coil resistance to absorb the energy).
So usually something across the switch is what is called for in order to limit the voltage and mitigate any issues. An R-C snubber, a Metal-Oxide Varistor, a gas discharge tube, a Zener, a reverse-biased diode, a semiconductor designed to avalanche, an active clamp etc. etc.
  • \$\begingroup\$ Thank you very much for your clear explanation. It seems I was mistaken to assume that the current would all flow back along the circuit and that the increased voltage would not be the direct cause of damage (e.g. electricity arcing through components with voltage threshold). \$\endgroup\$ Nov 11 '18 at 20:28
-1
All answers and comments here are true, but I like to add a shorter answer:
The voltage across an inductor is U=L*dI/dt. (This equation states that the voltage across L is proportional to the change in time of current through L).
If the switch was close before, there would be a steady current (no change of current and thus no voltage across L)
What happens if you open the switch?
Answer: The current will change instantaneously to zero, which produces a very high voltage across L. This high voltage can damage your circuit.
  • \$\begingroup\$ Thanks, I went through some of my sources and they did mention this as well, however I was not sure why the voltage would cause damage in the circuit (as per my mistaken assumption #3 leading to assumptions #4 and #5). \$\endgroup\$ Nov 11 '18 at 20:32
