I have LM358p op-amps Datasheet
I'm trying to base my design off this:
retrieved from here. My control voltage will vary between 0 and 3.5v. I want the output pulses to vary between 2.5 and 0.5ms and at a frequency of about 50Hz. This is to control a servo using Vcontrol.
My clock signal is from a 555 timer in astable mode. The square wave voltage is 0 to 8.4v.
I understand that this diagram is based on the ideal op-amp, so I'll need a resistor on the non-inverting input equal to the inverting input resistor. I'll also need a high value resistor parallel to the capacitor. The output will probably not reach 0v, but that's ok as long as the triangle is at least 2.5ms wide at its widest point.
I only have a single rail power supply, 0 to +12v to power the op-amp. The clock signal also never goes negative. I don't quite understand how the op-amp integrates. Is the non-inverting input the reference line, above which the integral begins to rise and below the integral falls?
What should my input pulses look like and how do I calculate the R and C values for the op-amp?
