I am working on a circuit:
My goal is to find \$ \omega_0, \beta, \$ and \$\varrho \$
The way I approached this problem was to first find the transfer function \$\frac{V_{out}}{V_{in}}\$.
KCL
- \$I_1=I_2+I_3+I_4\$
EFC
\$I_1=\frac{V_{in}-V{out}}{100000}\$
\$I_2=\frac{V_{out}}{\frac{1}{s\cdot c}}\$
\$I_3=\frac{V_{out}}{s \cdot l}\$
\$I_4=\frac{V_{out}}{400000}\$
\$H(s)=\frac{V_{out}}{V_{in}}\$
My result for the transfer function is as follows:
\$\mathcal{H}(s)=\frac{50000 \cdot s}{s^2+62500 \cdot s + 1000000000000}\tag1\$
My approach from here is to 1. Take the magnitude of this function, then find \$\omega_c\$ by substituting \$j\omega\$ in for s. From here set the magnitude of the transfer function equal to \$\frac{\mathcal{H}_{max}}{\sqrt{2}}\$ Once I have the cutoff equations then I can find \$\beta\$
I've tried the following
\$| \mathcal{H}(s)| = \frac{\sqrt{(50000 \cdot w)^2}}{\sqrt{(62500 \cdot w)^2 + (-w^2 + 1000000000000)^2}}\tag2\$
$$\mathcal{H}_{max} = \frac{R_L}{R+R_L}$$
Therefore,
$$\frac{\sqrt{(50000 \cdot w)^2}}{\sqrt{(62500 \cdot w)^2 + (-w^2 + 1000000000000)^2}}=\frac{\frac{R_L}{R+R_L}}{\sqrt{2}}$$
$$\omega = 31250 \cdot (5 \cdot \sqrt{41}\pm1)\tag3$$
I can find \$\omega_0\$ by taking the derivative of the magnitude =0 with respect to \$\omega\$
