Besides buying a Raspberry Pi with GPIO, what is involved in creating a circuit board that can send data to specific pins through a micro-USB cable, as well as read from data from sensors? I am open to designing my own PCB or using low-cost I/O controllers, but my knowledge is limited in what is actually required to design these interfaces.
For example, one usage would be:
1) Read temperature from an external sensor
2) send data to Android application through micro-USB
3) if temp > 80, turn on LED on the PCB
If I want to create many of these circuit boards without spending a solid amount of money, what would be the best method?
There are literally hundreds of micro-controllers with a USB interface, all of which can do what you want.
Most of them have example USB software.
Some of them have built-in temperature sensors, but adding an external chip like a I2C temperature sensor is easy and also eliminates the effect of the power of the controller.
You have to develop a tiny PCB with the chip(s) on them. I found writing the USB software at the PC/Android side the most challenging.
My guess is a prototype can be made for about $100 if you do it all yourself. Production price greatly depends on the volume.Your biggest cost in 10-100 up volume will be the assembly house. I estimate the materials at that volume are between $5 and $10 per board.
  • \$\begingroup\$ This is the clarification I was looking for, thank you! \$\endgroup\$
    – Bryan W
    Commented Nov 13, 2018 at 7:03
