I'm new to VHDL and I'm getting the following error when I try to compile my code:
** Error: F:\midterm night\assg 3\toplevel_design.vhd(18): near "<byte 0x93>": illegal character found in source
** Error: F:\midterm night\assg 3\toplevel_design.vhd(18): near "<byte 0x94>": illegal character found in source
** Error: F:\midterm night\assg 3\toplevel_design.vhd(18): Integer literal 0 is not of type ieee.std_logic_1164.STD_LOGIC_VECTOR.
Seems the problem is variable memory_block assignment.
library IEEE;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
entity mem8_16 is
port( clk,wr_rd : in std_logic;
  din : in std_logic_vector ( 15 downto 0);
  addr : in std_logic_vector ( 2 downto 0);
  dout : out std_logic_vector (15 downto 0));
end entity;
architecture memory of mem8_16 is
  signal memory_temp :unsigned (127 downto 0);
begin
  process(clk,wr_rd)
    variable memory_block: integer range 0 to 7;
  begin
    if (rising_edge(clk))then
      case addr is
        when “000” => memory_block := 0;
        when “001” => memory_block := 1;
        when “010” => memory_block := 2;
        when “011” => memory_block := 3;
        when “100” => memory_block := 4;
        when “101” => memory_block := 5;
        when “110” => memory_block := 6;
        when “111” => memory_block := 7;
      end case;
      if (wr_rd ='1') then
        memory_temp((memory_block * 16 + 15) downto (memory_block * 16)) <= din (15 downto 0);
      end if;
    end if;
    dout <= memory_temp((memory_block * 16 + 15) downto (memory_block * 16));
end memory;
The problem is that you have used some sort of word processor to create your source code, and it has inserted left- and right-double-quote characters (“ - 0x93 and ” - 0x94) rather than a proper ASCII double quote (" - 0x22) as delimiters around your string literals.
Use a code editor to edit code, and use the word processor to edit documentation.
Note also that there's no end statement for your process.
  • \$\begingroup\$ thx alot but i still have a problem with the line memory_temp((memory_block * 16 + 15) downto (memory_block * 16)) <= din (15 downto 0); \$\endgroup\$
    – m.rizk
    Nov 13, 2018 at 15:58
  • \$\begingroup\$ What problem is that? \$\endgroup\$
    – Dave Tweed
    Nov 13, 2018 at 16:05
  • \$\begingroup\$ Error: F:\midterm night\assg 3\toplevel_design.vhd(28): Target type ieee.std_logic_arith.UNSIGNED in signal assignment is different from expression type ieee.std_logic_1164.STD_LOGIC_VECTOR. \$\endgroup\$
    – m.rizk
    Nov 13, 2018 at 16:08
  • \$\begingroup\$ BTW, this is awfully clunky code for creating an 8x16 memory. Why don't you use an array like everyone else does? VHDL is already extremely verbose -- why make it worse? \$\endgroup\$
    – Dave Tweed
    \$\begingroup\$ Exactly what it says: memory_temp is declared as unsigned. din is declared as std_logic_vector. You can't assign one to the other without some sort of conversion. But there's no reason for memory_temp to be anything other than std_logic_vector since that's what din and dout are. \$\endgroup\$
    – Dave Tweed
    Nov 13, 2018 at 16:11
