The Sci-Toys project A simple laser communicator shows a surprisingly simple way to send an audio signal over a laser pointer.
A transformer AC-couples an audio signal directly into the DC supply to the laser diode, with it's high-impedance end in series with the battery.
I'm confused by the back-to-back diodes shown in the symbol for the laser diode. Is that standard?
I think that the basic idea here is that amplifying the audio to directly drive the laser without the DC supply would result in second harmonic generation and garbled audio, whereas the small signal addition to the DC supply would result in closer to linear modulation of the light intensity; a small signal on top of mostly bias.
Is there any chance that the DC current would be partially saturating the transformer's core? I seem to remember something about a very early design of an audio amplifier (before valves/tubes) based on modulated permeability. Is that an essential part of the function here, or just a red herring?
All images Sci-Toys
Sci-Toys simple laser communicator Sci-Toys simple laser communicator
The battery clip is attached to a 4.5 volt battery pack (not a 9 volt battery!). Since I didn't have a pack that takes 3 cells, I used one that takes 4 AA batteries, and I replaced one of the four batteries with a straight piece of bare wire.
  • \$\begingroup\$ The transformer is only being used here to avoid coupling DC onto the audio line; it's not being used as a mag amp as far as I can tell. If it was, you'd need a very specific transformer for it, and it would have to be tuned to the edge of saturation. \$\endgroup\$
    – Hearth
    Nov 15 '18 at 1:08
  • \$\begingroup\$ @Felthry Thanks. I mentioned the avoidance of DC coupling in the question, but I'm wondering if it is being indeed used for more than that. It seems as thought there is an opportunity to do some matching or at least optimization here as well. I wonder what the impact of the 125:1 turns ratio could be (Radio Shack (RIP) audio output transformer). Do you think it would matter if it were inserted the opposite way? \$\endgroup\$
    – uhoh
    Nov 15 '18 at 3:41
The back to back diodes are a bi-directional LED perhaps used as an indicator of over-drive. You could use two ordinary LEDs instead.
Those transformers can handle a more current before saturation than a laser pointer will want.
The transformer is used to step-up the voltage of the signal and to superimpose the AC sound signal onto the DC supply to the laser driver The approximately 11:1 step up by the transformer is less important than the way it allows the audio signal to be fed into the laser's power supply.
