I am designing a 6-layer board, with stackup like this:
1-TOP slow North/South
2-GND
3-Signal high speed East/West
4-Signal high speed North/South
5-VDD
6-Bottom slow East/West
PCB plane spacing is:
Layer1
- 4 mil -
Layer2
- 20 mil -
Layer3
- 4 mil -
Layer4
- 20 mil -
Layer5
- 4 mil -
Layer6
I'd like to take advantage of interplane capacitance and pour alternating GND and VDD pours. However, I am not sure how this will work in regards to maintaining a proper reference plane, as the reference plane will have to switch when moving from layer 3 to 4 for example, because the layer 3 pour will block the intial layer 2 reference.
Here is an example I threw together. Brown is GND, Blue is VDD, and Pink is the signal in question
Layer 1 VDD
Layer 1
Layer 2 GND
Layer 2
Layer 3 VDD
Layer 3
Layer 4 GND
Layer 4
Layer 5 VDD
Layer 5
Layer 6 GND
Layer 6
Non poured view
Non poured view
Is this a bad idea, or do I need to stitch vias everywhere to do this? Or will interplane capacitance take care of plane switching?
The circuits on my board I am concerned about are ethernet RMII, and QSPI signals clocked at 50mhz.
    \$\begingroup\$ There is no need to use 6 layers for 50 Mhz. The first PC Clones are at 133 Mhz and they use 4 layers, for example. \$\endgroup\$ Nov 16, 2018 at 8:29
  • \$\begingroup\$ Circuit density and 500mhz arm require it. \$\endgroup\$ Nov 16, 2018 at 12:52
  • \$\begingroup\$ You told 50 Mhz, not 500 \$\endgroup\$ Nov 16, 2018 at 13:47
  • \$\begingroup\$ Even if the ARM runs at 500 MHz internally, the interfaces external to it won't, they will still be 50 MHz. \$\endgroup\$
    – Justme
    Mar 5, 2021 at 12:58
Put stitching vias near the signal transition vias. It would help to sprinkle some 0.01uf to 0.1uf caps between VDD and GND. 50 MHz isn't terribly fast, but it is the rise time that matters.
