All voltages are referenced to ground unless otherwise noted.
SW1 = CLOSED; VA =
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityIf measurement section in Va has an infinite impedance then when switch SW1 is closed, then the equivalent circuit is
All current transfer from R1(zero ohm switch) and VA = 20.
No current transfer from 6K and 10K branch. and voltage in all point of this branch is 20V.
EDIT:
you can play with meter impedance and switch!
