Amazon sent me the wrong replacement switch so i am wondering if i can use it?
Original switch is AC 15A 125V / 10A 250V enter image description here
new one is AC 15A 250V / 30A 125V enter image description here
can i use it without damaging the appliance?
    \$\begingroup\$ 30A is better than 15A at 125V ..... 15A is better than 10A at 250V ..... the new switch can handle double the current at 125V and 50% more current at 250V ..... the new switch is better \$\endgroup\$ – jsotola Nov 16 '18 at 3:52
Yes you can use it. The replacement is more capable than the part it is replacing. This is a good thing.
| improve this answer | |
  • \$\begingroup\$ thx @Jasen I figured having bigger amps/volts meant it can handle more but I wasn't sure if the amps/volts were limits (like a fuse) and if allowing more through the switch could damage the appliance... so that is not the case then? \$\endgroup\$ – tsdexter Nov 16 '18 at 2:02
    \$\begingroup\$ indeed, not the case, the switch is either a conductor or an insulator, it doesn't perform any limiting or regulating. \$\endgroup\$ – Jasen Nov 16 '18 at 2:07
  • \$\begingroup\$ awesome thx @Jasen, so then the amps/volts on the label simply say how much amps/volts the switch can handle before being damaged but the fireplace should be sending less than its limits through it since the old, more limited, one worked fine? \$\endgroup\$ – tsdexter Nov 16 '18 at 2:17
  • \$\begingroup\$ that's it exactly. \$\endgroup\$ – Jasen Nov 16 '18 at 2:26
