I am going through and reviewing this unprofessional (I highlight a potential mistake in Section3.4) paper: Nonlinear Model & Controller Design for Magnetic Levitation System
Specifically, I am trying to compare the responses of the linear and non-linear model in Simulink, using the parameters provided in Table 1 of that same paper. I am to comment on any discrepancies.
I am having trouble comparing responses, since they are totally different from each other.I suspect that I may have a mistake/misunderstanding when it comes to plotting the non-linear model. A very brief summary of the paper follows.
System
Non-Linear Vector Format
Linear Model
Comparing Responses - Working
For the non-linear model I used a MATLAB function block, with the following script:
function y = fcn(u)
    % define your constants
    g = 9.81;
    m = 0.05;
    R = 1;
    L = 0.01;
    C = 0.0001;
    x1 = 0.012;
    x2 = 0;
    x3 = 0.84;
% nonlinear set of equations
x = [x2; g-((C/m)*(x3/x1)^2); -((R/L)*x3 + (((2*C)/L)*(((x2*x3)/((x1)^2)))))] + [0;0;1/L]*u;
y = x';
I then gave a step input to the system and got the following result. Yellow is the step input, green is the output.
Next, I proceeded with the linear model. I placed the matrices A, B, C and D inside a state space block.
To get the numbers you see above, I replaced the constants with the parameters given in the paper. I got the following output.
![enter image description here
As can be seen, both responses are completely different, and I am unsure about what discrepancies I should comment about. Are my non-linear and linear model implementations correct? I can add further details or workings if required.
Simulink build
Parameters:
Any help would be appreciated.
  • \$\begingroup\$ Re-calculate the bottom line of your \$A\$ matrix. \$\endgroup\$ – TimWescott Nov 16 '18 at 21:33
    \$\begingroup\$ I am getting: [0 116.66 -100] \$\endgroup\$ – rrz0 Nov 16 '18 at 21:45
  • \$\begingroup\$ Value seems correct... \$\endgroup\$ – rrz0 Nov 16 '18 at 22:08
  • \$\begingroup\$ A quick scan of your results tells me that (1) the non-linear model does't seem to be representing any dynamics, and (2) the linear model is not converging. Have you checked the eigenvalues of your linear state matrix? \$\endgroup\$ – Edgar Brown Nov 16 '18 at 22:08
  • \$\begingroup\$ I meant, recalculate the bottom line of your symbolic representation of your \$A\$ matrix. It is in error. (I'm assuming this is homework, or answers would be spewing forth). \$\endgroup\$ – TimWescott Nov 16 '18 at 22:49
Ah HA!. You used a Matlab nonlinear function block, but you're misunderstanding the system equation. The function \$\dot{\vec x} = f(\vec x, u)\$ is coughing up the derivative of \$\vec x\$, not \$\vec x\$ itself. You need to have a function block that just finds \$\dot{\vec x}\$ from \$\vec x\$ and \$u\$, then feeds it to an integrator (Simulink should be able to integrate a vector just fine) and feeds the \$\vec x\$ back to the block, and extracts \$y\$ from it.
Here's a block diagram of what you want to achieve (sorry for the crappy picture). I can't remember my Simulink well enough to say exactly how to do it -- I suspect you can make a multi-input, multi-output block, but if you can't you can make a concatinated input vector with x and u, and concatenate y and x-dot in the output, and use muxing and demuxing to get the data in and out.
| improve this answer | |
  • \$\begingroup\$ Thanks for the answer. The diagram is great, helped me understand what you meant. However, could you expand a little on how you came to the conclusion that the function is coughing up the derivative of x and not x itself? \$\endgroup\$ – rrz0 Nov 17 '18 at 17:05
    \$\begingroup\$ Because the vector on the left side is \$[ \dot x_1 \dot x_2 \dot x_3 ]^T \$, not \$[ x_1 x_2 x_3 ]^T \$. A dot over a variable denotes its time derivative. \$\endgroup\$ – TimWescott Nov 17 '18 at 18:00
