I'm looking over the results from a lab I did in an introductory electronics class, and found something I'm unable to explain.
We measured the rise and fall times for two logic gates in this absolute value circuit:
- The XOR gate in HA3 (U3,11)
- The AND gate in HA2 (U2,10)
The results were as follows:
$$\begin{array}{|c|c|c|} \hline \ & \bf{Rise} & \bf{Fall} \\ \hline \ \bf{XOR}& 44.8 & 64.0 \\ \ \bf{AND}& 51.2 & 19.2 \\ \hline \end{array}$$
This raises the following issues:
According to the datasheets (XOR, AND), \$t_{TLH} \$ should equal \$ t_{THL} \$ (typical value: 100 ns), which is evidently not the case for either of the gates (and dramatically so for AND).
Following on from the first question, why is the difference in the transition time reversed between the two gates?
The load capacitance should be slightly lower for the AND gate, as the path taken is shorter (with one gate less). This seems to be the case for the rise time, but not for the fall time. Why?
At first I though that the explanation would lie in differences in the capacitive loads impacting each of the gates differently. However, the load capacitance-transition time relationship should be pretty much the same (figures 6 and 12 in the XOR and AND gate datasheets, respectively).
