  1. AC current is sine wave with 60 hz frequency - how is this helpful in understanding electricity and transmission? Does the sine wave progress through electric wire or stands static and oscillates?
  2. when electricity enters the house through hot wire and is consumed by electronics, the neutral wire takes the unconsumed electrons back to sub station. Why is this simply grounded? is it not wasting electricity? can't the electrons be harnessed?
closed as too broad by brhans, mkeith, Dave Tweed Nov 17 '18 at 21:08
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
AC current is sine wave with 60 hz frequency.
No, the AC supply is sinusoidal voltage. The current waveform depends on the load but for resistor loads it will also be sinusoidal.
... how is this helpful in understanding electricity and transmission?
It's not sinusoidal to help with understanding. It is sinusoidal because we use rotary generators and the voltage output alternates positive and negative in a sinusoidal fashion as the magnets pass the coils.
The alternating of the current is more like a bicycle chain oscillating back and forth a bit. The chain moves very little but the effect is felt immediately at the other cog wheel.
When electricity enters the house through hot wire and is consumed by electronics, the neutral wire takes the unconsumed electrons back to sub station.
"Electricity" doesn't enter the house. Current does.
Current flows in a circuit - again like the bicycle chain. The number of links in = the number of links out. When you are pedaling your bike you don't "consume" the links. Current from the power station returns to the power station through the load.
Why is this [the neutral] simply grounded?
So that we only have to fuse one wire - the live. Since the neutral has been "neutralised" there is little voltage on it and no fuse is required.
Is it not wasting electricity?
No.
Can't the electrons be harnessed?
Don't think of electrons. Think of current. If you try to use the current in the neutral you will cause a voltage drop on the neutral wire and the voltage available to the original load will drop - possibly causing a malfunction.
You need to study basic electrical theory some more.
  • \$\begingroup\$ "It is sinusoidal because..." It is sinusoidal because that makes it far easier to step the voltage up and down, particularly with the technology available in the late 19th century. There used to be commercial DC power distribution (and, according to this wikipedia article there are still remnants today), but the world is pretty much running on AC today. \$\endgroup\$ – TimWescott Nov 17 '18 at 19:43
  • \$\begingroup\$ @TimWescott: No, it's alternating because this allows the use of transformers -- this has nothing to do with waveform. The AC waveform is sinusoidal because of how it is generated by rotating machines. \$\endgroup\$ – Dave Tweed Nov 17 '18 at 21:08
  • \$\begingroup\$ @DaveTweed: Point. Yes, I was conflating alternating with sinusoidal. Although, if you generated an alternating square wave that would make transformer and transmission line design fairly difficult in itself. If I remember my electric machines class, generator designers need to go to some trouble to insure that the output is nicely sinusoidal without much 3rd or 5th harmonics (it's probably easy to avoid higher harmonics than that, though). \$\endgroup\$ – TimWescott Nov 17 '18 at 21:15
