I think you made an error in reading that PCB layout. The two strings \$RF_{IN}\$ and \$RF_{OUT}\$ are not there to indicate that the polygons are connected to those pins, but that the connectors there are in and out.
Even if they were, keep in mind that at these frequencies, a DC short does not mean a short at high frequencies. This can lead to confusing results if you look at them in PCB software that is not built for high frequency design, as they don't take this into account.
The extra copper does not pick up extra noise (unless it happens to resonate and act as an antenna at a certain frequency). It will likely act as a shield, improving noise performance.
Since I want the traces of my input signal and output signal to have the same impedance as the SMA connectors (50 Ohms characteristic impedance) the trace width will depend on the distance between the signal layer and the ground layer among other parameters.
This depends a lot on the type of transmission line you are using. In this design they are using CB-CPW\$^1\$. This has a few advantages, such as potentially lower losses, more compact than microstrip and somewhat less sensitive to variations in thickness of the substrate. It combines the advantages of microstrip (big ground shield) and CPW (lower losses, less dispersion). Most important, however, is the fact that the ground plane gives you a very nice short between the two grounds on the top layer, suppressing the undesired odd mode. There are a few decent calculators online that should prove sufficient for designs such as this.
Layer 3 and 4 can usually be used for anything you want. It is however common to use at least one of them (generally layer 3) for your supplies, if you can't (or don't want to) do this on the top layer.
\$^1\$ CB-CPW stands for Conductor-backed CPW. Some literature will also call this G-CPW (grounded CPW) or CPWG (cpw with ground), most non-microwave/millimeter wave designers will just say 'CPW', but there are various types of CPW. 'True' CPW has one conductor layer with a ground-signal-ground mode, and the grounds extend to infinity. If you have CPW with a ground plane underneath, you have a somewhat different mode, and it impacts things. If you make it quite narrow (less than a wavelength or two of ground) it's really CB-FW-CPW (FW = finite width, so this would be conductor-backed-finite-width coplanar waveguide), as you start getting a significant error due to your grounds not actually being infinite.
The mode of CB-CPW is a hybrid between that of a CPW line and a microstrip line.
