I design a board based on ATMEGA328P (as in Arduino UNO). Now I am busy creating a power line. My controller will be installed on the electrical panel, so I need to provide a reliable, noise-resistant device.
Once in the examples, I saw a 180 ohm`s resistor that was installed between VCC and GND. What does this resistor give to the board? Should I use it?
Resistor
I also assembled a chain of SMD capacitors (4 normal and 1 polar). Should I change the number of capacitors or their capacity?
Capacitors
    \$\begingroup\$ "Once in the examples, I saw a 180 ohm`s resistor that was installed between VCC and GND. What does this resistor give to the board? Should I use it?" Post a schematic of the circuit, not just the resistor - nobody can say what it's doing in your example if you don't show the example. \$\endgroup\$ – user133493 Nov 18 '18 at 6:19
I will start with the capacitors.
That arrangement is correct, you use a bunch of ceramic .1 uf capacitors near the pins to decouple high frequencies and a big electrolytic one to help with low frequencies and keeping voltage stable in case of a mini power loss
i would make some additions to the input circuit though
this would filter out high frequency noise coming from the power line as well as preventing your circuit from injecting noise to it, the 1 ohm resistor is there just to avoid any possible resonance and the inductor should be a very low q one or even better a ferrite bead like NFZ03SG501SN10D, these one are specifically designed for EMI filtering you will have to choose the correct one for your application
on the 180 ohm resistor, i am really not sure why is it present, my guess is that it guarantees some load on the supply so if a transient occurs the voltage stabilizes faster and to provide some noise immunity by lowering the load impedance
the obvious disadvantage is that you would be wasting power, if that's a concern i would suggest getting rid of it
now the most important part however to make the circuit noise resistant will be the layout, normally sticking to the following rules is enough:
1: keep the traces short and straight
2: unless you have some requirement don't make them extremely thin
3: use a ground plane, as uninterrupted as possible
4: keep decoupling capacitors near the pins and put a vias close to their ground pads
  • \$\begingroup\$ Thanks for the detailed answer and tips on designing the board! I will use your power filter circuit. \$\endgroup\$ – Delta Nov 18 '18 at 6:59
