I am using LTC3624-3.3 regulator, with components as in the datasheet app notes - 12 V Vin, burst mode, 10 uF at in, 47 uF at out, 2u2 inductor rated at 2.3 A...
At no load, voltmeter says 3.34 V. Good. But with 47 ohm resistor across output (i.e. 70 mA load), Vout drops to 3.20, and at 10 ohm - 330 mA, to 3.05 V. This indicates practically no regulation. I changed output capacitor from tantalum to ceramic X5R, inductor from 2u2 to 10u, and neither changed anything.
Has anyone had no-regulation with LTC3624? Could part arrangement cause this? I believe I satisfied all design considerations from the datasheet, except that Vin trace runs for a 5-6 mm parallel to SW trace with 2 mm gap and with ground flooding on the bottom PCB layer...
