I read that in almost all daq board datasheets the analog inputs are specified as single ended or differential inputs.
But the same daq have digital I/O ports. How can one understand whether the digital input is differential ended or single-ended. Or are the default one of them?
For example from a manual:
16 single-ended (SE) or eight differential (DIFF) analog input channels
Eight individually configurable digital I/O channels
As you see the differential or single input nature of the analog inputs are specified. But for digital inputs no information.
How is CM noise for a digital signal rejected ?
Which one of the opamp represents digital input?:
Edit:
The black is the pulse waveform below, and the red is the noise superimposed on it. So if the system were diff ended and inputs were diff ended the red CM noise would be rejected. But for digital inputs red will never be rejected since it is swinging between the thresholds?:
There will be no single/differential end digital i/o 's
  1. single end: Measure the voltage between the input signal and analog ground.
  2. differential end: measure the voltage between two distinct input signals.
digital inputs will be either HIGH/LOW with respect to Ground
CM noise rejection: actually lets say there is a bridge sensor. The sensor measurement of ADC is independent of the low level ground which makes it more free of noise. The reason for this is that the noise source is present on both signal leads and when in differential mode only the difference between the two leads is measured.
Regarding your both the images
first image is differential ended analog input
second one is single ended analog input
if a digital signal heve noise lets say, but enter image description here
it will receive that data as
since usually in most of
TTL cirucits
0 to 0.8V - LOW
2 V to VCC - LOW
if in cmos
0 to 1/3VCC - LOW
2/3 to VCC - HIGH
there is a lot of width b/w LOW and HIGH
  • \$\begingroup\$ How about RS485? Isnt that digital? \$\endgroup\$
    – GNZ
    Nov 18, 2018 at 22:19
    \$\begingroup\$ RS485 IS an communication standard. here i am giving information on digital and analog pins. \$\endgroup\$
    – Electron
    Nov 18, 2018 at 22:21
  • \$\begingroup\$ I see but the diff analog inputs are useful to reject CM noise as you know. Isnt there a similar way for the digital inputs? \$\endgroup\$
    – GNZ
    Nov 18, 2018 at 22:22
  • \$\begingroup\$ I mean how is CM noise for a digital signal rejected ? \$\endgroup\$
    – GNZ
    Nov 18, 2018 at 22:23
  • \$\begingroup\$ Differential analog inputs are mostly used to measure Bridge type of sensors and measuring a sensor value with reference to other \$\endgroup\$
    – Electron
    Nov 18, 2018 at 22:24
