I was following this online tutorial and cannot get the interrupt-based timer to work. I know the timer is running because if I uncomment the five lines in the main loop, I get a nice square wave output. But with those lines commented out, the timer interrupt is not firing and I cannot figure out why. Can someone suggest what I'm doing wrong?
#include "stm32f4xx_hal.h"
void SysTick_Handler(void)
HAL_IncTick();
HAL_SYSTICK_IRQHandler();
static TIM_HandleTypeDef s_TimerInstance = { .Instance = TIM2 };
void InitializeTimer()
__TIM2_CLK_ENABLE();
s_TimerInstance.Init.Prescaler = 160;
s_TimerInstance.Init.CounterMode = TIM_COUNTERMODE_UP;
s_TimerInstance.Init.Period = 100;
s_TimerInstance.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
s_TimerInstance.Init.RepetitionCounter = 0;
HAL_TIM_Base_Init(&s_TimerInstance);
HAL_TIM_Base_Start(&s_TimerInstance);
void InitializeLED()
__GPIOA_CLK_ENABLE();
GPIO_InitTypeDef GPIO_InitStructure;
GPIO_InitStructure.Pin = LD2_Pin;
GPIO_InitStructure.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStructure.Speed = GPIO_SPEED_HIGH;
GPIO_InitStructure.Pull = GPIO_NOPULL;
HAL_GPIO_Init(LD2_GPIO_Port, &GPIO_InitStructure);
void TIM2_IRQHandler()
HAL_TIM_IRQHandler(&s_TimerInstance);
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
HAL_GPIO_TogglePin(LD2_GPIO_Port, LD2_Pin);
int main(void)
HAL_Init();
InitializeLED();
InitializeTimer();
HAL_NVIC_SetPriority(TIM2_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(TIM2_IRQn);
for (;;)
// int timerValue = __HAL_TIM_GET_COUNTER(&s_TimerInstance);
// if (timerValue == 50)
// HAL_GPIO_WritePin(LD2_GPIO_Port, LD2_Pin, GPIO_PIN_SET);
// if (timerValue == 100)
// HAL_GPIO_WritePin(LD2_GPIO_Port, LD2_Pin, GPIO_PIN_RESET);
