first some specifics:
STM32F411 Nucleo board, Atollic TrueSTUDIO v9.1.0, Debian linux 9.6.
I am sending a telemetry string over the UART using the HAL. I am using the following code to construct and transmit the data:
sprintf(str, "#, %d, %d, %s\n", csvString.range, csvString.lux, csvString.time);
HAL_UART_Transmit(&huart2, str, strlen(str), 100);
where '#' is the telemetry sentence start character, and the data follows a pre-formatted CSV type structure for easy manipulation on the receiving side. If I do a simple
cat /dev/ttyACM0
I can see the output, which looks like:
#, 21, 114, 01:58:001
so that looks like it's working well. However when I attempt to use a simple python script to parse this information in, I get a mess. It appears to be an encoding problem. The python that I'm using looks (as an excerpt) like this:
ser = serial.Serial('/dev/ttyACM0', 115200, timeout=2, parity = serial.PARITY_EVEN, bytesize = serial.EIGHTBITS, stopbits = serial.STOPBITS_ONE)
if ser.isOpen():
ser.close()
ser.open()
ser.flushInput()
ser.flushOutput()
line = ser.readline(100)
ser.close()
and the result I get out of this reading of 100 bytes off the UART (just a sniff to see if things are working properly) looks like:
#\t\x920\t\x8a1\x13\t\xa22\xa7\xb2:\x820\xe1#\t\x922\t\x8a1\x13\t\xa22\xa7\xba:\x821\xe1#\t\x921\t\x8a1&\t\xa22\xa7\xba:\x821\xe1#\t\x923\t\x8a1&\t\xa22\xa7\xba:\x821\xe1#\t\x921\t\x8a1&\t\xa22\xa7\xba:\x821\xe1#\t\x920\t\x8a1\x13\t\xa22\xa7\xba:\x82
There is an obvious repeating pattern in this, which looks like it lines up with the telemetry sentences. I can't use some of the other methods in python to read off the UART easily because they can't detect newline characters in this.
It's obviously an encoding problem, but I'm not sure how to solve this as:
- I do not know how to (even after searching) verify the transmit encoding used by the STM32 HAL/Compiler
- I am not a talented software person
Could the community please:
- Help me determine what the encoding being sent is
- Give an example of how to decode it so that I can then write code to parse things as I need to
Thanks!
EDIT: To address a comment suggesting evaluating the UART data using an oscilloscope, I can not do this as I am using the UART bridge on the STLink part of the STM32 Nucleo board. I am not currently able to switch to the other UART as those pins are in use. It would also not account for why I can see the data properly formatted if I display the output of the device in a terminal session (the above mentioned cat /dev/ttyACM0). Thank you for your suggestion.
parity = serial.PARITY_NONE
(instead ofparity = serial.PARITY_EVEN
). \$\endgroup\$
