First of all, please see my other question HERE as it is related (Any help with that is greatly appreciated too).
If you read through my other question, you will know that I am attempting to interface with a magnetic sensor IC, the MLX90393, on the Sparkfun Breakout Board.
I have been having trouble reading the data from it, and I am confident the issue is in the code, not any of the hardware. The reason for this, is when I use the ARDUINO EXAMPLE CODE on GitHub, with the Arduino IDE (still using the STM32 Nucleo hardware), everything works and I can read the data from the sensor. However, when I attempted to convert that code over to mbed, I just get an error, and I am unable to extract the data.
I have now decided to see what would happen when trying to do a scan to find the address. Previoulsy, when doing an I2C scan in the mbed IDE, I got an ACK from every single address. The code I used was HERE. When running this code, this is the response I got:
Please note I added an additional \n after "I2C device found at...." so that it didn't scroll across the screen. Please note I have tried it with Error ==0 and 1. When I use Error ==0 for mbed, I get 'No devices found'
This is almost an exact copy of the Arduino I2C scanner, which can be found HERE. Looking through the 2 of them, they are basically exactly the same, and I cannot find the difference between them (bear in mind this is my first time working with I2C). When I run this code on the same hardware but via the Arduino IDE, this is what I get:
Does anyone have any idea why this is happening? What is the difference between doing this with the Arduino IDE and the mbed? I hope solving this issue may assist in solving the issue with my other question, but this is really getting frustrating. I have tried changing I2C pullups to different values and that had no effect either.
